Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Canon sd 750 faceplate replcement
I dinged the faceplate on my new camera and want to replace.
Looks like three screws hold it in place. Is this a easy fix or do I need to take to a camera shop?
  • Canon Master
  • 4,738 Answers
It's usually an easy fix. But really would recommend leaving it be if the camera is 100% functional.
The trick is finding a replacement at a reasonable price (usually from broken cameras off of ebay). Here's some examples of disassembly of older models from the sd series. Note that yours is somewhat different, but it still should be a doable project:
Posted on Mar 04, 2008
Canon SD 750 all images blurry on left side
service the focousing unit of the lens,if needs replace the unit.
Apr 02, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
In ixus 750 it shows memory card error with all memorry cards
First of all, make sure that you are using a standard SD card2.gif (2GB or less) and NOT an SDHC card (4GB or more). Though an SDHC card looks exactly the same as an SD card, it is not. As your camera came out before the SDHC format, there is no way to make an SDHC card work with your camera. If your card is SDHC, just hang onto it. Someday you'll have a newer camera capable of using it.
But if your card already is standard SD, see this link for additional things that you can try.
Sep 25, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
The lens bayonet on my T70 is loose. Where do I find the screws to tighten it?
I've read that some of the "Handymen" out there have taken the faceplate off the T70 and put LocTite on the screws to hold them in place. OMG--not for me. Look on the web for a Canon authorized service center. I only paid $15 for my secondhand T70. I just leave the 500mm bazooka lens off it. A modest lens up to 135mm should be okay. Good luck.
Jun 23, 2009 | Canon T70 35mm SLR Camera
Need new mannual
You can download user manuals for the Canon Powershot SD750 from Canon's website at this link.
Dec 14, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Display issues with Aiwa CDC X207
I had the same problem. There are two small light bulbs that illuminate the digital display, and they are burned out.
You can easily replace them. The Aiwa part number for them is 8Z-KT1-641-010. The bulb is made by Sony, and the Sony part number is U0087654U.
I purchased them from Union Electronic Distributors:
Note that the product is not an item they keep in stock, so it may take 1-2 weeks or more before you receive them. Be patient.
Here are the steps to replace the bulbs. You will need a small (#1) Phillips screwdriver and a soldering iron (low heat). A very small flat blade screwdriver (1/8") will also be helpful.
1) Remove the faceplate from the radio and bring it to a well-lit work table.
2) Remove the four Phillips screws on the back on the faceplate.
3) Carefully separate the back half of the faceplate cover from the front half. There are three locking tabs along the top, and three locking tabs along the bottom. I used the small flat blade screwdriver to separate the two halves.
4) Once the back half of the faceplate has been removed, re-install two of the Phillips screws to hold the circuit board in place (one screw on each end). You don't need to screw them down tightly; just screw them in until you begin to feel them stop. These screws will keep the circuit board from separating from the front faceplate and causing the buttons to fall out!
5) Locate the two bulbs. They are labeled PL 901 and PL 902 (may also be labeled PL 1 and PL 2). Carefully unsolder the bulbs and remove them from the circuit board. You may want to do one at a time.
6) Each bulb has a colored cover to change the color of the light (I jokingly refer to them as 'bulb condoms'). Remove the covers and carefully slide them in place on the new bulbs. You may want to slightly dampen the bulbs to aid in sliding the covers on. Be sure to slide them all the way down.
7) Solder the new bulbs in place. They are not polarity sensitive.
8) Trim off the excess wires.
9) If you installed the two screws in Step 4, remove them.
10) Carefully re-attach the rear faceplate cover to the front faceplate cover, making sure that all six locking tabs snap in place.
11) Put the four Phillips screws in the rear faceplate and carefully tighten them.
That's it! Now, put the faceplate back on the radio, turn it on, and enjoy your lighted display!
Hope this helps.
Dec 13, 2008 | Aiwa CDC-X204 CD Player
Dropped my Canon SD 750 and it won't turn on
Nov 07, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Need to replace faceplate for nokia 5300
Start by removing battery. Then remove the camera plastic panel. After that you will need to loosen the screws holding the faceplate in on the top. You will require a special tool for this but it can be purchased from most places that sell DIY faceplate kits.After careful prying the faceplate should come loose. Keep in mind that the screen over the LCD screen is taped on and will need to be removed separately.
Oct 24, 2008 | Cell Phones
Olympus stylus 710
I just wanted to follow up that we ordered the replacement part from the website another poster listed:
The part came in three days and it was SO EASY to replace. You just need a tiny Phillip's head scewdriver and about three minutes. Remove the three small screws that attach the faceplate to the camera (one on the bottom, two on the side). The faceplate pops right off and exposes the hinge that holds the battery door in place. Remove the final screw that holds the hinge in place. Reuse the original spring, pop the new door in place and then replace the faceplate.
Just like new! :)
Nov 09, 2007 | Olympus Stylus 710 Digital Camera
Dropped it to the floor, new CANON SD 750
you seemed to have broken a vital part. Nothing for us or you to do. A repair- I feel will be very expensive Checkout Canon support- but I fear you will not like the response.
Aug 21, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
337 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
