Question about Ovens
Oven is giving a F1 code and is not working . It beeps even when it is not given a program.
  • Ovens Master
  • 19,396 Answers
Hi.
The error meaning depends on the oven brand.
On Amana and other brands F1 is a faulty control pad or faulty electronic control.
That may be your case , since the electronic control looks being jammed.
Try tripping the circuit breaker for two minutes (or disconnect power cord). If that does not help, then call the manufacturer at the number listed on the owners manual.
Note: on other brands F1 indicates incorrect temperature , and is associated with a faulty temperature sensor. This normally does not cause the electronic control beeping and not responding.
Regards.
Posted on Mar 04, 2010
When turning oven on there is a beeping sound and error code F1
Most of the answers are correct, the EOC (Electronic Oven Control) is either damaged or shorted. I've also seen the F1 code come up on the version 2 and 3 units when the temperature probe was shorted. But most likely your EOC is damaged and needs to be replaced. Since you didn't give us a model number we can't give you any more info. Good luck
Mar 14, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Oven is beeping and showing f1
Hello Charlie,
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
GENE
Nov 06, 2011 | Neff B1421 Electric Single Oven
F1 code GE profile convection self clean wall oven (95?) oven beeps F1 code oven works when it is on bake etc. when touch key are pressed it goes off but starts to beep again
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Sep 19, 2011 | Ovens
Oven beeps and show F1 and F3 while trying to cook or even 2hrs after cooking.
F1 code is a "EOC (Electronic Oven Control) failure" Replace your oven control
F3 code is a bad oven sensor the sensor should have a ohm reading of 1100 at room temp. Replace your oven sensor as well.
Dec 06, 2010 | Frigidaire 30" Built-In Single Electric...
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Jun 21, 2010 | GE Profile JT952 Electric Double Oven
The oven beeps and has a error F1
Hello,F1 means Stuck touch pad.
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled,replace the oven control(also called clock or ERC),touch pad,or both.
Thanks
Jun 01, 2010 | GE JTP20 Electric Single Oven
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
GE Profile Double Oven F1 Error
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
&*&^%rt
Aug 08, 2009 | GE Profile JTP56 Electric Double Oven
Oven "beeping" wont stop
Sep 12, 2008 | Kenmore 47722 / 47724 / 47729 Electric...
Ovens Logo
146 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
