Question about HP Color LaserJet 2600n Printer
Wont print continuously on Cardstock
Even when I configure it to print on cardstock. It will do it for some time and the repeatedly jam up.
Any ideas?
  • CiCi385 Mar 06, 2008
    Thanks! but it printed up 3 x 5 cardstock - to the tune of 150+ no problem
    it jams on full pages, go figure.
    Oh well, I've figured out how to work around it.
    Thanks again!
    Master:
  • 555 Answers
The cardstock you are using might be to heavy or rough for the 2600n to use.
FOr this printer HP recommends paper no thicker than 0.18 mm (7.0 mils), and between 100 and 250 on the Sheffield "smoothness" scale.
More information on recommended paper weight and smoothness is available here:
http://www.hp.com/support/ljpaperguide
Posted on Mar 03, 2008
Paper always jams even without starting,,,,specially when im going to print cardstock, it never works
Jams from where? Need more info. Cardstock must be printed from the Bypass Tray ONLY. Make sure you select the proper paper type from the Printer Properties tab in the driver.
Oct 13, 2014 | Ricoh Genuine Aficio Mpc6000, Mpc7500...
Can't print on cardstock (110lb) with out the printer jamming...
You must change the printer settings in software to let it know it is using cardstock. This will adjust the roller height so the printer will not jam.
Mar 04, 2011 | HP Officejet J5780 All-In-One InkJet...
Cardstock won't feed
You need to hand feed these things.....one at a time. I sometimes find that I have to "help" it a little bit to get it feed by putting just a bit of pressure on the paper to push it into the feeder. Another trick is to make sure the front edge is turned up just a bit. (I usually take about 10-15 pieces of cardstock and roll them, and then feed them one at a time) that seems to work pretty well, too
Jan 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
My piece of cardstock paper keeps jamming barely out of the tray. is there something i can do to have it go all the way through. I have a samsung clp-315 laser printer.
Yes, you have to change the print properties on the computer to let the printer know it is using cardstock. Please refer to the owners manual to get the information. The manual can be found at www.samsung.com under the support section.
Nov 26, 2009 | Samsung CLP 315 Laser Printer
My 5610 wont print on cardstock, creates paper jam!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-2
Jul 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Samsung ML-2510 Laser Printer Jams
printer only supports up 120gsm,anything thicker will jam.
Jun 08, 2009 | Samsung ML-2510 Laser Printer
Paper too thick?
You will need to use the manual feed and insert the cardstock one page at a time. First look at the rear of the printer for a purple dial. Roll the dial downward. This will allow the printer to exit straight out the back of the machine. Allow enough room at the rear of the printer so the cardstock doesn't hit anything on the way out. Next look at the front of the machine at the **** just above the paper tray. You'll see an envelope icon. Align the cardstock when manual feeding one sheet at a time to the left side of the **** next to the envelope icon. When you hit "file, print" select MANUAL FEED in the print window.
The 4L will only do cardstock by one at a time in the way noted above as the feed system isn't strong enough to make the sharp bend coming out of the tray or in the back to bend it around and into the top tray.
Sep 22, 2008 | HP LaserJet 4L Printer
Paper keeps jamming
To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
Jul 08, 2008 | Brother HL 1440 Laser Printer
HP 2575 Jamming on cardstock paper
most likely that printer would do it if it were brand new, but after a period of time, the mechanism becomes 'tuned' to a certain size paper..
you may need to realign the rollers, etc, to accept the thicker paper.
my recommend..go to a local print shop with paper and images/data on cd, and let them do it.
May 08, 2008 | HP Photosmart 2575 All-In-One InkJet...
HP Color LaserJet 2600n Printer Logo
353 people viewed this question
Seeker5211
Seeker5211
