Question about Dishwashers
While dishawaher was going, heard
While dishwasher was going, heard it "fizzing" & could smell a "hot" smell -tried it again & it blew the plug fuse -repaired this, but dishwasher not going at all.
Checked under dishwasher & there was no water.
Thanks
  • DIYer in ME Jan 05, 2009
    The control timer will not power up when the door is closed, but the timer is energized when the door is held more firmly closed by hand. But...it sounds like the mechanical (?) timer gears are catching when the door is closed the additional amount needed to activate the door switch.
    Is the door switch adjustable on the Maytag MDB6000? If so where is it located and how is it accessed?
    Thanks
    Sergeant:
  • 351 Answers
Check inside the control panel and see if the door micro switch ar some wiring is burnt.hope this helps
Posted on Mar 04, 2008
Blew the fuse, now wont work.. and an electrical smell...?!
you will have to have a technician inspect the damage to see if it can be repaired before you make a decision on replacement
May 25, 2017 | Fisher and Paykel Dishwashers
How do i fix dyson DC41 Animal vacuum upright cleaner it has burning smell coming from motor and it blew the fuse box when i WENT TO VACUUM. the wire flex is a bit over twisted
You most certainly shorted this out and will need a new cord. Easy fix but you will have to take it apart and find where it failed. I doubt the motor fried but it is possible. When you take it apart look for the burn mark left by the electrical arc. That is the point you fix.
Dec 26, 2015 | Dyson DC41 Animal Bagless Upright Vacuum...
No power. Will not turn on
It may have tripped the internal breaker, and or the house circuit breaker. Go tot the house fuse box and check that first.
Mar 05, 2014 | Whirlpool Gold GU2275XTVy Dishwasher
My Whirlpool GU2400XTP dishwasher keeps blowing the fuse. It sat up for 6months because the control panel went out and I couldn't afford to get a new one. Finally replaced the panel and the thermal fuse...
Are you replacing the wires along with the fuse? It is important to change the wires too as they are usually the cause for the fuse blowing. Be sure and get the fuse kit that includes the wires.
Is your water too hot? Hot water is fine but too hot of water can cause the fuse to blow over time. The temp should be somewhere around 120 F. Anything over 130 F is way too hot. I personally don't use a long high steam final rinse or high heat because over time the steam and cause the electronics to short as steam and moisture can get into the keyboard and inside panel.
Apr 04, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
DW blew GFI fuse and spartked out junction box
unplug it and check the junction box its probably shorted there
Feb 07, 2010 | Frigidaire 24 in. FDBB944C Built-in...
I plug in my dishwasher and the fuse blew in the socket any ideas shall I try again with another fuse?
No it sounds like a fault. Did the fuse blow immediately or during the program. A multimeter should be used to test for short circuits.
Jan 24, 2010 | Dishwashers
Oven blew a fuse
The POP sound normally indicates a short circuit fault (as opposed to overload) you need to have it looked at by a competent person.
Nov 17, 2008 | Ovens
Diplomat dishwasher blows fuses
I would disconnect the heater then run the unit.If it runs the heater is bad,if the fuse blows again the motor is most likley bad.make sure there are no water leaks.let me know.happy holidays
Dec 05, 2007 | Dishwashers
Dishwashers Logo
139 people viewed this question
Top Dishwashers Experts
