Sylvania tv my tv is messed up i will be watching it when all of a sudden the picture will disapear into just one fine line so then i tap it and the picture will come back i have to do it a few times and dont know what the problem is can anyone help please.
  • 52 Answers
I know your problem for sure. If the fine line you are seeing is horizontal, you have a bad capacitor (or cold solder joint) in the "vertical deflection" circuits. Look for four of the largest wires coming from the picture tube and follow them down to the circuit board. These wires do NOT come out of the BACK of the tube, where most of the wires come from, but rather come sort of from the side of the tube. Two of them will go down to the board near the largest component on your board known as the "flyback transformer". Disregard these two and follow the other two. They will go near either two transistors or a vertical deflection chip. The board will normally be labeled "vertical" or vertical deflection near these transistors. There will be two or more capacitors very near these transistors. Look at them on the underside of the board and look for a bad solder joint. Push on the capacitors left and right while observing the underside of the board and you might be able to see the bad joint. If it is a chip instead of transistors, you could still have a bad capacitor or cold solder joint, but in most cases if it's a chip, then the chip is bad. Since, however, you can tap on the tv and make it work temporarily, this tells me that you probably have two vertical deflection transistors with associated capacitors. If the caps are good and no cold joints, then replace the transistors. This part of your tv is what pulls the electron beam up and down vertically and is thus called the vertical deflection circuits. With no vertical deflection, then the beam just moves left and right and never moves up and down. The picture is still there, but it is contained inside the fine line where of course you cannot see it. The parts in this circuit are not expensive at all. Keever
Posted on Mar 03, 2008
Sylvania tv srt2232s picture is dark. i have used the remote gone to pictureand still unable to adjust brightness. need your help to adjust brightness. What do i need to do to change the brightness
Remove back fron tv locate line flyback transformer
on this transformer there should be two adjustment controls very carfully adjust the bottom one, do not adjust to far as picture will have fine white lines on it
May 17, 2010 | Sylvania SRT2232S 32" TV
The picture just suddenly disapeared on our tv while we were watching it. There's sound but no visible image.
check the video cable, try replace the cable or interchange it , if the picture ok but sound become missing then the cables is damaged. Or check the large IC resolder the leads.
Aug 08, 2009 | Televison & Video
Sylvania 6842PE
This is a power source problem and it will need to be fixed by a pro! This is a very common problem with the Sylvania sets! (cost to fix 250.00-350.00)
Please rate answer to keep this site FREE!
Dec 28, 2008 | Sylvania 6842PE 42 in. HD-Ready Plasma...
32" sylvania TV thin line
There are bad solder connections on the vertical IC. This is a small flat IC attached to a heat sink. It should have about 9-11 pins and may be marked LA7837 or something similar. Resolder the pins on this IC and that should resolve the problem.
May 07, 2008 | Sylvania SRT2232S 32" TV
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
TV Dilemma
you have a stuck vhs tape in it.
Oct 20, 2007 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
Sylvania 6620LCT 20
throw it in the landfill there are no replacement parts.
Oct 09, 2007 | Sylvania 6620LF4 20 in. EDTV-Ready LCD...
Televison & Video Logo
146 people viewed this question
Top Televison & Video Experts
