Question about Saeco Magic De Luxe Espresso Machine
No power! We have had our Magic De Luxe for 4-5 years. We use it several times a day, every day! After dispensing two shots, the whole thing just shut down, no power! I unplugged it and replugged it in; tried an new outlet; I hit the green and and off switch on the bottom; I completely cleaned it out. Still no luck. :( You suggestions would be greatlyu appreciated.
  • mack paulk May 11, 2010
    It probably has a thing called a thermistor in it, which is a safety shutoff to prevent fire when a problem occurs. If the thermistor is defective, it could very well shut you down after being on for only a short time. Unplug it and take it apart. Go ahead and give it a try. Some thermistors are round, about the size of a half dollar piece with two connectors. Just unplug the two wires, remove the thermistor, and replace it with a new one and re-connect the wires. Other thermistors are the shape of the pointed end of a pencil and are about 3/4 inch long and about as big around as a pencil. There will be a wire coming out of both ends. Cut these wires, unless they unplug, and replace the thermistor. To help find the thermistor, follow the three plug wires into the machine. Forget the green wire. The thermistor will be connected to one of the other two wires, usually the black one. New thermistor should cost only $5 or $10 bucks, if not less. Keever
    Scholar:
  • 70 Answers
Keever's right. Thermistor inside the machine. Saeco will not sell it to you. Has to be sent into a repair center.
Worse case it could also be the board and here's where the bad news comes in.
Saeco does not carry the magic deluxe boards anymore.
Posted on May 25, 2008
How do i turn off the descaling light
Hello info 11220,
I understand you need to turn of the descaling light on you Saeco Magic De Luxe Expresso Machine. The only thing you need to do after you get done descaling the unit is to hold down the steam button for 5 seconds and the light should go out. If you have any more questions please feel free to ask.
Thank you for choosing FixYa.com
Justin
Mar 09, 2011 | Saeco Magic De Luxe Espresso Machine
Tip
Fix Saeco Magic De Luxe Not Grinding problem
If you leave the machine for a while, the residual ground beans in the grinder stick and clog the grinder.
- thus "timing out" with the "No beans" light.
After taking apart the grinder and cleaning it out, it still didn't grind. -
Then we ran some ground beans through it a couple of times, and then put fresh whole beans on top of the preground, and it took.
Worked great after that.
on May 06, 2009 | Saeco Magic De Luxe Espresso Machine
No Crema
Hi
If your talking about the tube on the brew unit, you are probably missing the spring or if you have the spring its upside down. Again if this is what you are taking about is the check ball at the bottom of the spring(ball in first, small end of the spring on the ball, O-ring, then the manifold)These things are important for creama.
Nov 08, 2009 | Saeco Magic De Luxe Espresso Machine
After steaming milk, going back to making another espresso shot
try change termostat (small white with two yellow wire)on tank if still doesnt work your computer is gone.
Aug 25, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Magic Deluxe resets itself before completing brew cycle
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that doesn't fix it, then you might need a new flow meter.
Jun 12, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic de luxe not grinding beans
Try setting the grind to the coarsest setting, if you still have the same problem, check the wire connections to the board, it might have been reversed.
May 05, 2009 | Saeco Magic De Luxe Espresso Machine
Water pump not working
Can you please try firstly making a "Pre ground Coffee" on your coffee machine by selecting the pre ground button and making a coffee without coffee in the bypass.
If that doesnt work, let me know.
If it does, open slide the grinder right up to the coursest setting and see if water comes through.
Once again if that doesnt work let me know.
Oct 31, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Machine coffee grinds drawer overfills with water
Hi The thumb screw on the brew unit is stripped. If you remove the brew unit and you have water where the thumb screw is its stripped. you just need to remove the old one and replace it.
Oct 13, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe dregs light problem
Make sure that both the tray and dump box are placed correctly- otherwise the machine will not start. Both have a switch and when that switches are not engaged, the machine will not turn on.
Mar 09, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Veinna no power
There is an overheat protector on the boiler. If the unit is a newer say 2 years or younger some of the sensors are weak an pop thus shutting down the whole system. You would have to take the unit completly apart to get to it (not recommended) Google "authorized Saeco Repair and find a repair center and have them fix it. Probably less than $100
Aug 16, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
145 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
