Question about Saitek (PS28) Joystick, Throttle
X52 calibration From time to time the joystick loses calibration and dosnt center as it should. I cannot find a calibration mode to reset it, and have to resort to turning off the p.c. and rebooting to get it centered once again. What am I missing?
  • 2 more comments
  • halobba Oct 08, 2008
    Whan I attempt to calibrate my Saitek X52 the settings are in the halfway range.(box is half in the red) Throttle is already at half speed. In my attempt to fly the aircraft the plane automatically moves at half throttle, and will not stop. How do I calibrate the settings .
  • Anonymous Jan 03, 2009
    The stick makes my plane in Flight Simulator X turn to the left so I also have some problem with the calibration settings, any fix on that one?
  • Anonymous Mar 22, 2009
    All controls on my throttle part are offset, joystick is ok...
  • hutch226 Apr 02, 2009
    I cant get more than 50% range of movement on the x52. Looking at the throttle view, it does not go below 50% power....There appears to be no calibration facility anywhere I look....?
Have the same problem with my X52; cant get the rudder control (twisting control) work fine, but it goes on its own way to the right and can't be calibrated no way. this is my 3rd SAITEK X52 (2 X52PRO, 1 X52), and all I can say is: SAITEK IS THE WORST **** I EVER HAD IN MY LIFE.
Posted on Dec 03, 2010
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Calibration is not really something the Saitek X52 needs: there are no "resistors" or "swipers" that need to be adjusted over time. The axis sensors are Hall effect sensors, with no moving parts, and thus the "center" state of each axis is digitally controlled. Such noise is caused by loose ps2 connectors, bent pins, sloppy usb contact, etc.
That said, errors or jitters in the centering of the stick is now in the realm of "electronic noise" interfering with the control system. The computer reads the inputs (even the noise/static) as control inputs, and adjusts the stick position on the fly.
Now if its a windows10 problem, that started only after upgrading, that's a whole other story (I know how to fix it as well- reply if this is the case)
Posted on Dec 04, 2015
My saitek x52 joystick wont work. Flashing lights every half second. Throttle works fine.
My X52 began doing this after hundreds of hours of use. Joystick lights flashing twice per second. Throttle operative but joystick (and buttons) not.
The problem was 2 wires inside the joystick base that had eventually been sawed in half by the sharp edge of the metal tube that carries the wires up into the stick. I have no doubt that this same issue could cause intermittent operation if just the insulation is worn off of more than one wire.
The fix: Remove the 4 screws from the base and lift the joystick assy out of the base. Inspect the wires where they emerge from the metal tube. You will find wires broken, or, insulation rubbed off. If you have broken wires, strip the ends and solder them together...you should have about 1/4 inch of "slop" up in the top end so you can pull the top wires down enough to strip and solder. If you re-insulate the solder splices with heat shrink or spaghetti tubing I would keep the amount used minimal...these wires need to remain somewhat flexible when the stick is being used.
Finally, I fixed the engineering defect that caused this in the first place by immobilizing the wire bundle with hot glue at the tube opening to prevent future contact with the sharp tube end. If your only problem was skinned insulation, this hot glue application may be all you need to do to keep the exposed conductors from contacting each other or the tube.
Speaking of "slop", you will also be contending with a bunch of silicone grease that lubricates the wire and mechanism.
Jun 12, 2011 | Saitek X52 Flight Control System
I have Microsoft Flight Simulator X and a Satek X52 flight control, however I have problems with the throttle on all aircraft. I have to use the F-4 key - can you help?
You need to assign the throttle function correctly WITHIN FSX settings area itself. Also calibrate the joystick in windows first. If you are not familiar with assigning FSX functions to your joystick, check the Learning Center section within FSX for step-by-step details.
Feb 24, 2010 | Microsoft Flight Simulator X for Windows
My joystick will not respond.
you have to plug the round tipped courd into the slot in both controllers, connecting both. you only plug one thing into your computer and that is the usb cord built into the throttle control.
Nov 16, 2009 | Saitek X52 Flight Control System
Logitech zero calibration reset method
Have you tried using the Logitech calibration uninstall tool that erasers all joystick calibration from windows.
Download and run the Logitech Clear calibration (LWS_CLRC.EXE).
The Clear calibration Utility was developed by Logitech to resolve calibration problems with Logitech digital gaming devices.
NOTE: This utility strips all calibration information in the Windows Registry for all gaming devices. This includes any non-Logitech gaming devices that have been installed.
You may also want to uninstall and reinstall the Joystick Software as well. In some cases, if the calibration issue is within a game, you could try uninstalling and reinstall the game.
Please refer to your game manufacturer for instructions on uninstalling or configuring the game.
Note:
This calibration tool specifically mentions the Wingman Joystick, However, it works for ALL Logitech and NON logitech Gaming Joysticks and Gamepads.
Jun 06, 2009 | Apple Logitech Freedom 2.4 Cordless...
Saitek X52 Joystick
Try deleting the drivers for the joystick, visit Saitek website get latest drivers and re-install the joystick, might fix the problem.
Nov 23, 2008 | Saitek (PS28) Joystick, Throttle
Some buttons don't work
Pioneer AVIC-D1 Touch Screen Recalibration
If your pioneer AVIC car navigation unit does not register your touches or the wrong button is “pressed”, you need to re-calibrate your screen’s digitizer.
1-Hold the Eject button down until the face of the unit drops all the way
2-Using a pen hold down the reset button (just above the joystick) and the navigation disc eject simultaneously.
3-Release the reset button.
4-Release the dvd eject button next. The display will read “press reset”
5-Push the joystick up two times.
6-Push the joystick down twice.
7-Press the joystick in.
8-The service menu will appear after a short pause. You can navigate the service menu using the joystick.
9-Chose the first menu option and press in on the joystick.
10-Trace the screen with a stylus.
11-"P.ADJ" is the back button
12-Chose the second menu item in order to calibrate the touch screen. Use a stylus again and tap the "+" sign on the screen. (You may have to touch slightly off center if the digitizer is damaged. In which case things will still be off but it will be much better.)
Jul 27, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
X-axis trouble
I had the same problem with my X52 and searched high and low on the internet for a solution. What I did was pop the base off and found a loose connection on the x-axis wires. I re-routed both the x and y axis contact wires underneath the p/s2 port and put it back together. Seems to be working fine now. I will not that opening up the controller will void your warranty and it also could be possible that your x-axis problem could stem from something completely different from what was wrong with mine. You may contact me if you need any help with it. mynameisbob AT gmail DOT com.
Jul 19, 2008 | Saitek (PS28) Joystick, Throttle
Saitek aviator joystick av8r-01
Well.. if you have windows xp.. then you can calibrate your controller fairly easily.
Go here:
Control panel:Printers and Other Hardware:Game Controllers:(your controller should be in the list):Advanced:Calibrate
This should solve your problem ;)
Apr 11, 2008 | Saitek Aviator AV8R Joystick
Promblem
Normally there is no reason to re-calibrate the Logitech Cordless Action Controller for PlayStation2. In rare cases where the mini-joysticks may need to be re-calibrated, you can use the process below. Please note that this process only works for the Logitech Cordless Action Controller for PlayStation2.
  1. Remove one battery.
  2. Hold the L1 and L2 buttons while re-inserting the battery. (NOTE: Do not touch or move the mini-joysticks at all during this time. It is very important that the mini joysticks are allowed to center themselves during this step or the calibration procedure will not be successful.)
The mini-joysticks should now be re-calibrated. Please note that in some cases you may need to resynchronize the gamepad and receiver after this procedure.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=1414
Aug 13, 2007 | Logitech Cordless Action (9633200403) Game...
Saitek (PS28) Joystick, Throttle Logo
2,367 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Rob Emerson
Rob Emerson
juanmireles1
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
