Question about Citoh Office Equipment & Supplies
Linux Printer Driver for Citoh ci5000 printer
Convering from DGUX to Linux. We Linux will not print properly to the CI5000 printer in IBM/Epson mode. Need help.
ohms
  • 1879 Answers
SOURCE: I need driver Epson TM-T88IV for linux Suse 11
go to this site to get detailed information:
http://www.epsondevelopers.com
wrote a tip http://www.fixya.com/support/r672100-epson_impact_printers_mac (mac's are unix)
Posted on Oct 10, 2008
kywriter
  • 25 Answers
SOURCE: ibm 4230 driver
Try IBM Proprinter III XL, 3287, Epson FX, Any Dot Matrix Printer Driver. The 4247 drivers cannot be used for the 4230.
The 4230 is a seriously old printer. You might want to consider getting a new one.
Posted on Mar 18, 2009
SOURCE: I am new to Linux. How do I instal an Epson SX210
Try this:
http://blog.sadhill.net/impresora-epson-stylus-sx210-en-ubuntu
Posted on Feb 22, 2010
SOURCE: looking for linux drivers for Epson SX215 printer
get the Epson Linux drivers from the Avasys site and install them
http://www.avasys.jp/lx-bin2/linux_e/spc/DL1.do
Posted on Jul 20, 2010
SOURCE: my new epson r230x printer is printing text and images blur
i have r230 printer but they r no blank paper image and text plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz help me
solve this problem plzzzzzzzzz
thanks
my id pirzadarehan@yahoo.com
Posted on Aug 12, 2010
How to you know if your new Tallygenicom printer 6312 is compatible to your system?
The answer to this depends very much on what sort of system you are using......
If it is a Windows System you can simply install the Windows Printer Driver and use the printer as a normal Windows Printer.
On Unix / Linux you can set the printer up (usualy using CUPS) in this case you can use one of the standard device types and select a corresponding emulation on the printer-
Set the printer to Epson FX emulation and use a Epson 9 Pin printer driver
Set the printer to IBM Proprinter emulation and use an IBM Proprinter priver (9pin)
On the AS400, iSeries, Seriesi you can also use the Epson FX emulation or IBM Emulation and select the corresponding device type on the host system
Other systems may support similar functionality.
You can also send plane text files to the printer, or alternatively program you own escape commands to control print features.
So like I say it depends on the system you are using, perhaps a good place to start is by contacting Support for the Computer Application or System you are using to see if they support Dot Matrix and or Line Printers.
It is not possable to give a generic "Covers all Systems" answer, unfortunatly
Sep 10, 2010 | TallyGenicom 6312 Matrix Printer
Tip
Linux Drivers for Inkjet/Laser Printers and Scanners
Linux Drivers for Inkjet Printers, Laser Printers and Scanners
Open Source and Proprietary software developments for popular printers and scanners.
  • Currently HP provides Linux printing support for over 1,200 HP printers.
  • Canon periodically releases Linux drivers for certain PIXMA & i-SENSYS products based on global demand.
  • EPSON Linux Drivers is proprietary and is developed and distributed by AVASYS.
  • Brother has prepared a CUPS driver (For BR-Script Models Users) and a CUPS wrapper driver (For Non-BR-Script Models Users) package. The CUPS driver automatically copies the relevant driver files to your Linux distribution, and the CUPS wrapper driver makes LPR drivers work with CUPS.
click here for more information and downloads.
on Jan 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I have ubuntu 10.04 using printer epson lx-300 how to install . Give step by step
http://free-linux-trick.blogspot.com/2009/06/how-to-install-printer-driver-epson-lx.html
Aug 19, 2010 | Epson LX-300+ II Matrix Printer
How do you reset the 2390 back to the factory default ?
www.lexmark.com/publications/pdfs/form2400/en/enUser.pdf
Shows you how in above manual.
. Turn off printer 2. Move print-head all the way to the left, so it's hitting the left hand wall of the printer. 3. Hold down Alt and Setup while turning printer on. Keep pressed down until you hear the beep and the printhead moves. This can take 5-10 seconds. Hold in the keys and make sure the printhead is over to the left when you do.Note: The printer defaults to IBM mode, this is fine in MEDENT except for letters and prescriptions. If you do factory default and they don't print MEDENT letters or prescription then make sure MEDENT printer setup for type 11 (IBM mode). If they do letters or prescription, then change the printer setup to Epson mode See Also: Switch Emulation Mode from IBM to Epson
Apr 09, 2010 | IBM 2491 Dot Matrix Printer
Try this:
Jan 21, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
SOFTWARE FOR C.ITOH CI 5000 PRINTER
hi
you can download the driver for citoh ci 5000 printer here
for windows 2000 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_2000/17280.html
for windows nt - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_NT4/17279.html
for windows 85 and 98 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_98_95/17281.html
or you can choose your own...
http://www.updrivers.com/drivers/Printer/Citoh/17/86/page2.html
thanks bye
May 19, 2009 | Itochu C.itoh CI 5000 Matrix Printer
Ibm 4230 driver
Mar 18, 2009 | IBM 4230 Model 4S3 Matrix Printer
Printing from Microstation to Epson Stylus C62 printer
Hi AW
More info is needed. Does the printer print normally from Windows programs? Is the "microstation" running under Windows, or if not, what operating system? If it's not a standard operating system that has C62 drivers (DOS, Windows, Linux, Mac), you will have to write your own driver I'm afraid. Let me know.
Gerry
Nov 13, 2008 | Epson Stylus C62 InkJet Printer
98 people viewed this question
Top Citoh Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Citoh Office Equipment and Supply Expert? Answer questions, earn points and help others
