Question about LG WM-2277HW Front Load Washer
LE Error i have the LE error. I replaced the rps sensor and the Main PWB (the main board) what else can I replace or check. The water pump works because it drains out the water, but all hear is noise from the pump when I check the spin in the QC test
    Sergeant:
  • 351 Answers
Is ther any broken wires between the board and the rotor sensor
Posted on Mar 04, 2008
The washer is stopping midway through the load and an error codeLE what seems to be the problem
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
but if this does not helps then the actual reason of LE error code is as follows:--
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
The hall sensor seems to be part of the motor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
Dec 20, 2010 | Samsung WF337AA Front Load Washer
Washing mashin is writing error LE what does it mean?
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
May 06, 2010 | Samsung WF337AA Front Load Washer
Kyocera fs 9530 - f040 error
this error came because of the Defective harness between engine PWB and main PWB or improper connector insertion. open both board and re fix it and check ....... please mention your correct printer model in next comment so we will give you idea how to open the boards ....... restart your printer and check it ...........
Main - Engine controller PWBs communication
error
• The communication breakdown occurred
between main controller PWB
and engine controller PWB during 30
seconds.
cause
Defective engine controller PWB........Defective main controller PWB.
solution
Replace the engine controller PWB
Replace the main controller PWB
Dec 21, 2009 | Kyocera FS-2000D Laser Printer
How do I clear error code LE? I do not want to call for service.
LG
Washer Fault Codes Failure Code Condition Check/Repair "IE" Water inlet error. Cause : Correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes Ensure your taps supplying the washing machine are turned on. "UE" Imbalance error. Cause : The load is to small, the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum. Move the washing around inside the washing machine to create a more even distribution of weight "OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge "FE" Over flow error. Cause: water is overflowing (water level frequency is over (213) When FE is diplayed the drain will pump out automatically. "PE" Pressure sensor error. Cause: the sensor switch assembly is out of order. "dE" Door open error. Cause: door not all the way closed, loose electrical connections at door switch and pwb assembly.The door switch assembly is out of order. Gasket on door maybe creased in. Try opening and closing the door, sheck to see the gasket isn't jamming "[-E" Heating error. Cause: the thermistor is out of order. CE Over current error. Cause: Main PWB assembly is out of order, Winding in the stator assembly is short circuited. LE Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective. bE Ball sensor error. Cause : Loose ball sensor connector,ball is out of order. This is displayed only when the start / pause button is first pressed in the OC test mode. EE (EEprom error) Cause: EEprom is out order. Displayed only when the start / pause button is first pressed in the OC test mode. PF Power failure. Cause : the washer experienced a power failure. E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages. Return to top
MAYTAG
Stackable A/W and Dryer Fault
Dec 02, 2009 | LG WM-2277HW Front Load Washer
What does an ''LE'' code mean on a LG Model WM2075CW
Hi
Thanks for using FixYa. Make sure the error is not IE, which means water has not reached to the pre-set level within 4 min. since ERROR inlet valve operated or water has not reached to the normal level within 25 min.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error, but it is possible to separate the working from the non-working, just by following a process.
To make sure its not a locked motor, try turning the drum with your hand. And, if you feel some resistance while turning the drum or the drum doesn’t move freely then the motor is locked and you’ll need to get it replaced.
The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour.
Also check for ---
  • Check for the Connector (3 pin, male, white) in the Wire Harness, check if it is connected to the Connector (3 pin, female, white) of MOTOR. Reconnect or repair the connector.
  • The electric contact between the connectors¡a3 pin, male, white in the Wire Harness and 6 pin, female, white in the PWB ASSY(Main) is bad or unstable.Reconnect or repair the contact in the connector.
  • The Wire Harness between the MOTOR and PWB ASSY(Main) is cut(open circuited).Repair the damaged (open-circuited) WIRE HARNESS
  • The hall sensor is out of order/defective.Replace the PWB ASSY(Main).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 12, 2009 | LG WM-2077C Front Load Washer
LE light came on and washer stopped. Tried another load, washer filled but does not run
The LE code means a motor error. Lock error, you may have to try replacing the Hall Sensor and if this doesn't fix the problem then you need to replace the Stator as there may be aproblem between the Stator Assembly and the main PWB Assembly.
Nov 08, 2009 | LG WM2688HWM TROMM SteamWasher
My LG washing machine will not run through washing cycle
Locked motor error (LE)
* The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly
* The electrical contact between the connectores, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit).
* The hall sensor is out of order/defective.
***. If the hall sensor is defective, replace the entire motor.
Jul 13, 2009 | LG WM1814CW Front Load Washer
Samsung washing machine shows error "LE"
Jun 14, 2009 | Samsung WF203ANW Front Load Washer
LE error message when washing. Drum will not spin
May 25, 2009 | LG WM-2077C Front Load Washer
LE error code on LG washing machine Model WT-R801, goes through all cycles, then when supposed to spin it comes up with this error, even on a small load.
Looking at several LG Washer service manuals, the error code LE ( Lock Error) could be any one of several things: a 3 pin connector in the wire harness going to the motor, It could also be the harness itself between the Motor and Circuit Board Controller ( PWB) assembly has been damaged or cut..or the hall sensor used to detect drum speed while it rotates may be defective or the main control board ( PWB) "printed wire board " is defective. Lots to pick from but these are the likely candidates... hope this helps
Aug 08, 2008 | LG Washing Machines
LG WM-2277HW Front Load Washer Logo
94 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
