Question about LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW 16x6x16x DVD-R/RW 40x24x40x CD-R/RW 5x DVD-RAM 8.4GB 4x +... (ODDWG4163O) Burner
External Drive I have dropped my external drive and now it is not working. However, when I plug the wire in, it turns on for about 3 seconds. Also, when I pull out the cd/dvd drive a smell of something burning comes out. Please can you help me?
  • 40 Answers
Sounds like you broke something internally, and it is shorting out when you turn it on. I would suggest properly disposing the drive and buying a new one, as external drives are not worth fixing, and if it has a burning smell it is most defiantly a fire hazard.
Posted on Mar 03, 2008
  • Daniel Spagnoli
    Daniel Spagnoli Mar 08, 2008
    no need to give you a low rating for telling you how it is...
How to access my Buffalo HD-PNTU3 external hard drive?
dropping it while turned on is fatal as it usually damages the write heads and/or the platters.
if it hit the floor, changes are it's physically damaged the mechanism.
recovering data from a drive with this damage is not cheap as you will have to send it away to be rebuilt. It's impossible to rebuild it yourself.
Feb 21, 2016 | Buffalo Technology Buffalo MiniStation...
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Toshiba external drive won't instal on Windows 7 Home Premium
Will the external drive work on another computer? Has the external drive been dropped, bumped, jarred? If it works on another computer, shut down the Win7 laptop, unplug, remove battery, remove the USB external plug, plug into AC, reboot, when it is finished, plug in USB.
Jan 13, 2013 | Computers & Internet
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
Wd3200bmvs-11f9s0 not being recognised by any computer. do the jumper pulgs need to be bridged in any certain way
hello
do this and it should work : unplug the power and USB cords from the external WD drive
wait 20 seconds. plug the power cord into the drive (make sure the other end is plugged into the wall)
wait 20 seconds, plug the one end of the USB into the computer, and the other end into the WD external drive.
in a few seconds, your computer should see and activate the WD external drive.
thanks for using FIXYA -- please make sure to send me 4 thumbs up
May 10, 2011 | Western Digital Passport 320GB External...
I connect the travel drive and it keeps disconnecting/dropping connection and sometimes it will not reconnect. Other times it will and disconnect again almost immediately. Or sometimes I am going thru a...
If you are talking about an external drive, there could be several things to cause the problem: 1) cable plug could be loose at either end, 2) cable could have been bent too sharply causing wires inside to be damaged 3) USB plugs could be bad on computer.
I use a USB extension on my USB computer plugs to save wear and tear on the plug itself. 4) there could be loose connections inside the external drive 5) the drive or the electronics inside the box could be going bad. I usually figure on about 2 years on an external drive, then I replace it.
Dec 22, 2017 | Memorex Ultra Traveldrive - 160GB USB Hard...
I have a iprodrive external hard drive and my laptop does not reconize it any more. the last time i used it i did not disconnect properly. is there a way to reset it
Here a step by step guide i found as i surf the net last week. Read along.
  1. Step 1 Log in to your computer as the administrator.
  2. Step 2 Install the external drive software from the CD that comes with your external hard drive.
  3. Step 3 Use the USB cable that came with your external hard drive and plug one end of the cable into your hard drive and the other into the USB port in your computer.
  4. Step 4 Give Windows a moment to recognize the external drive and to assign it a drive letter.
  5. Step 5 Go to the "My Computer" icon and double-click on it.
  6. Step 6 Choose the newly created external drive letter in the right-hand explorer window.
  7. Step 7 Right-click on the external drive letter and choose "format" from the drop-down box.
  8. Step 8 Choose "quick format" from the format options section from the next pop-up box.
  9. Step 9 Click the "Start" button.
  10. Step 10 Click the "OK" button in the Format warning box.
  11. Step 11 Click the "OK" button in the "format complete box" to finish the process.
Should you have any questions regarding this post feel free to post it here.
  • Step 2 Install the external drive software from the CD that comes with your external hard drive.
  • Step 3 Use the USB cable that came with your external hard drive and plug one end of the cable into your hard drive and the other into the USB port in your computer.
  • Step 4 Give Windows a moment to recognize the external drive and to assign it a drive letter.
  • Step 5 Go to the "My Computer" icon and double-click on it.
  • Step 6 Choose the newly created external drive letter in the right-hand explorer window.
  • Step 7 Right-click on the external drive letter and choose "format" from the drop-down box.
  • Step 8 Choose "quick format" from the format options section from the next pop-up box.
  • Step 9 Click the "Start" button.
  • Step 10 Click the "OK" button in the Format warning box.
  • Step 11 Click the "OK" button in the "format complete box" to finish the process.
  • Read more: How to Reset an External Hard Drive | eHow.com http://www.ehow.com/how_4840145_reset-external-hard-drive.html#ixzz0YYmAf0Ra
    Jul 24, 2010 | Computers & Internet
    SimpleTech SimpleDrive 640 GB external USB harddrive wont turn on
    Loose connection inside the Drive case. Remove drive and check internal wiring.
    Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
    External Hard Drive doesn't work
    There is a (laptop-size) hard-drive inside the case, and that hard-drive is failing. As it spins, it generates those noises, like a dying dinosaur. If it still is under warranty, exercise the warranty, and replace it. If the warranty has expired, tough luck.
    May 21, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
    Segate FreeAgent 750GB external hard drive
    my iqube extenal hard drive is not working was dropd down, I have tryed plag and play and it shows the light and fun inside working and when you staart uyou can ear like its start but stops after few seconds
    Oct 15, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
    Computers & Internet Logo
    Top LG Computers & Internet Experts
    Alun Cox
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
