Question about Panasonic PT-51HX41 51" Rear Projection Television
Had a question about the Panasonic PT 51HX41 51 in. projection
I had one of the same problems as listed on one of the forums about this model shutting down after about 5 seconds. It actually never really turns on, just sounds like it is about to, then after two clicks its off and the power light is blinking once every 5 seconds or so. You said to replace the convergence amps, model STK..... anyways, I did that and I still have the same problem. You had mentioned to replace any 2.2 ohm 1w feed resistors in front of the convergence amps that had changed value. I didn't do this, and I am wondering if any would need to be replaced if their value changed, or if it should still work without repacing them. Should I go back and do this, or look elsewhere to resolve the problem? Any help is much appreciated! Thank you!
  • codyecp Mar 03, 2008
    One other thing, sorry, is there a trick to putting the screen back on after cleaning? I had it all taken apart so I figured what the heck, I'll clean the screen, now it takes on a concave shape wich will def. cause convergence issues with the HD. Wondering if there is any trick to flattening that out?
  • 934 Answers
The 2.2 ohm resistors in that circuit are the yoke return voltage and yes they could be the problem. Using a dmm or analog meter test the ohm resistance of each resistor. You may find one that is open possibly. But change any that are off by more than 10% and/or obviously stressed.
BTW re-check your solder connections on each of those amp pins. Make sure you haven't soldered two pins together or missed one.
As for the screen, they fit into a track on the framing. Look closely and you'll probably find where it's hanging on the track and not letting the screen seat into the track.
Bill
Posted on Mar 13, 2008
Shuts off after being on for 15-20 mins... can turn right back on after.. why is it doing this??
Set may shut down for a number of reasons--the model listed here had all kinds of troubles with the Lamp and its Ballast and was recalled years ago.
Jun 13, 2012 | Panasonic PT-50LC13 50" Rear Projection...
Tip
Panasonic PT-52LCX66 Manual Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66...
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Have you lost the Operating Instructions for your Panasonic PT-52LCX66 Projection HDTV?
Click here to download a digital, searchable copy of your users manual / owners guide.
I hope that helps.
on Apr 11, 2010 | Panasonic PT-52LCX66 Projection Television
My panasonic pt-56wx53g projection tv from 2003, shut off and the red light flashes 3 times every 10 seconds. hharris@dallascounty.org
The 3 flashes is the error code for failed convergence. The Panasonic PT53WX53 Convergence repair kit fits your model. Its available at www.tvrepairworld.com the kit contains the ICs, Resistors and the CD with step by step repair instructions.
May 29, 2011 | Panasonic PT-56WX53 53" Rear Projection...
My tv powers on and then shuts off in a few minutes. I love this tv and the picture looks great, i think its a fan problem. But not sure.
Do you see any light lit solid/ blink when tv shuts down?
Let me know is it Panasonic PT-50LCX63 or any other model?
Above info will help me to diagnose problem and to suggest a solution.
Thanks.
Jan 24, 2011 | Panasonic PT-50LCX63 50" Rear Projection...
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Rear projection 50" keeps shutting off and turning on
Your Balister is shot, replace for about $600 or Go to consumer affairs and search on your TV model, there are all types of issues. Please file a complaint and join our growing list to get Panasonic to support its customers.
Aug 28, 2009 | Panasonic PT-50LC13 50" Rear Projection...
My panasonic tv pt-47wx51e color looks like 3d how can i fix this
There is a convergence kit available for your model which contains the new ICs and resistors plus the instructions of how to install the repair kit on CD. Heres a link look under Panasonic repair kits and you will see your model listed.
www.tvrepairkits.net
Jun 26, 2009 | Panasonic PT-47WX51 47" Rear Projection...
Finding mirror glass replacement in projection tv
THe part n umber will be dependent upon the exact model number of your set. Can you please post that model number. This entry is listed under model number PT-47WX49. Pleaes confirm the model so we can get the proper part number.
Thanks,
Dan
Feb 09, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Color shift
There is going to be 2 ICs. Both should be replaced at the same time.
May 12, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
