Question about Compaq Presario 5BW284 (202493-003) PC Desktop
Message usb powersurge
Last night the computer showed usb powersurge. the computer froze we had to unplug and went to restart. there is power to the tower, however the monitor starts with a green light then right to a yello one. nothing comes up on the monitor at all, it is pure black.
any help will be greatly appreciated
  • 1 more comment
  • cophil Mar 04, 2008
    a message came on the screen saying usb powersurge. Then the computer froze. I haven't had a power surge otherwize that I am aware of. As for the power supply fan, yes it is still working.
  • cophil Mar 11, 2008
    Thanks for the advise, I tried that and still nothing. The computer seems to turn on, however; still a black screen.
  • AL Arena May 11, 2010
    How did the computer show a USB powersurge? Are you aware of a power surge otherwise? Is the power supply fan (in the back of the computer) working?
    The symptoms sound like a surge damage the power supply, it's connectors, or to the motherboard. I saw the same symptoms 2 weeks ago. I replaced the video card and it seemed to work. The next day the screen kept blanking out. I pulled the power supply and replaced it. When I looked at the motherboard connectors on the old power supply 3 pins were burned. So far things are OK with the new power supply.
I had the same problem. I heard a sparking noise, then that message popped up and the computer froze. I havent been able to get it working since then. When i plug in the power source (everything else is unplugged) the power light in front as well as the LED power light on the back just blink on and off, no sounds or fan. I have tried replacing the power box, to no avail. I have also inspected the logic board for any burning or anything else that might be causing it. Please Help!!
P.S. I also have a compaq presario
Posted on Jul 09, 2008
    Scholar:
  • 67 Answers
I doubt if it's the monitor, but if you have a spare you should try it. Failing that, it might be time to go inside the computer. First step would be to pull the connectors going from the power supply to the motherboard. Examine them for scorch marks. If there are any, replace the power supply. Try installing another video card, if you have one. This can get expensive so you may want to shop around for a local tech with reasonable rates.
Posted on Mar 11, 2008
  • 492 Answers
A usb power surge occurs when a usb device is drawing or providing too much power to a port. I would recommend replacement of such device before continueing. To trouble shoot what it is unplug all usb devices, start the computer, then plug devices in one by one.
Posted on Mar 07, 2008
Hello, After putting my computer, hp pavilion m7690n, to sleep last night. I woke up to see it was turned off so I went to hit the power button to start it up but it didn't show any power because the...
It's possible that your computer froze during sleep. First, unplug the power cord, (with the cord removed) press the power button for 10-20 seconds. PS: You will lose any unsaved data prior to sleep mode. Let me know if this doesn't resolve your problem, might be something major.
Jul 01, 2013 | Computers & Internet
When plugging my hard drive in my computor tells me that there is a powersurge and the usb port cannot deal with it ? how do I get around this ?
If you get an error message"Insufficient power to operate USB device" when you plug a USB deviceinto the computer's USB port, then this device is drawing excessive currentthat the USB port cannot supply. In case such as this, youneed to purchased a powered USB hub and connect this hub into the computer'sUSB port and then connect the USB device into this powered USB hub.
Dec 31, 2010 | Iomega Computers & Internet
I tried to put my pictures onto my computer last night but the computer froze so I gave up but I took pictures this morning, and it was fine. Then the next picture I went to take nothing showed up on the...
Your coin battery that powers the memory system of your camera may be failing. This battery keeps your settings and powers your on board computer. Do not confuse this with your picture battery, as that only powers the lens and picture taking ability. The coin battery holds the program. See page 38 of your manual "Replacing the Date/Time battery."
Dec 20, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Power surge on usb hub port in compaq nc 6120
Yeah--I've seen that before and perhaps you can check it out by unplugging all USB devices and restarting the computer. If you still get that message, go into your control panel and under device manager remove all the USB devices. Restart the computer and let it find the devices again. If the problem persists, you have a motherboard issue. Might be OK, but if you can isolate the particular hub that is giving you the problem, avoid using it.
Dec 23, 2009 | HP Compaq nc6120 Notebook
Powersurge on USB ports
Have a close look at the USB ports, make sure you don't have any bent contacts touching the outer part of the connector and shorting.
May 04, 2009 | Dell Latitude D410 Notebook
Beep codes instructions:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bph07107&dlc=en&product=362754
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
My sansa is spazzing out
Go to settings - USB Mode -- msd; and make sure the port on your computer is a USB 2.0 port.
Jul 05, 2008 | SanDisk Sansa e250 MP3 Player
Silver ps2, red light only, no power up
The live wire may be detached,
SoThere may be an internal problem and You can show it to a mechanic nearby you.
Jan 24, 2008 | Sony PlayStation 2 (PS2) Console
Desktop monitor
Hi
Disconnect the monitor from the tower and then turn on the monitor.
If u get a msg like no input signal or check video cable then the monitor is fine. If this is the case, it could be a problem with the tower or the cable.
Dec 31, 2007 | Compaq Presario 5BW284 (202493-003) PC...
Power outage last night. Deleted all saved voicemail messages. when turned on - machine says "no massages" How do I retrieve lost messages?
I'm sorry there isn't. Answering machines like this have very little ROM memory. After a powersurge and outage like last night, it wiped the whole memory chip. You can try there support page. It's actually pretty good. http://telephones.att.com/telephones_ui/support/index.cfm
Jun 28, 2007 | Lucent 1872 Corded Phone
Compaq Presario 5BW284 (202493-003) PC Desktop Logo
289 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
