Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Neptune mah4000aww belt wont stay on drive wheel
Hey
there is a brown residue all over the floor under and on the tub , water pooled on the floor and the belt wont stay on it looks like its in good shape but as the wheel starts to cycle back and forth it works itself off. what do you think? jimmy
  • jamesthegood Mar 03, 2008
    good job master_tech will follow up on your advice thanks
  • 770 Answers
Lost you on chat you closed the window
plz email me
Posted on Mar 03, 2008
We keep getting a brow film around the edge of the hot tub.
That is normally iron in your water. It often happens in cottages that are beside lakes and have bore wells. In your case with a hot tub, it is a residue that comes off the people using it!
Body Chemicals - This is the most common cause of film in hot tubs. It's caused by deodorants, hair products, perfumes, and lotions. ... Poor Water Chemistry - Water with improper pH levels and bad calcium levels can cause buildup and lead to film floating on the water or collecting on the sides of the hot tub.Apr 7, 2016
Foam And Brown Film - Hot Tub Water Chemistry - Pool and Spa Forum
https://www.poolspaforum.com > Pool/Spa Water Care > Hot Tub Water Chemistry Oct 24, 2008 - 11 posts - ‎6 authors
Hi all New to the Hot Tub World New to the forum. ... The reason the film is brown is iron in the water absorbs into it. .... to realize that foam downs are bandaid fixes and don't do anything to eliminate the cause of the foam.
Use CLR.
CLR Calcium Lime Rust Remover
what causes brown film in hot tub Google Search
Jun 23, 2018 | Pool & Spa
I have a may tag Neptune washer model # mah4000aww. When I spin the tub it sounds like there is still water in the washer. Clothes are coming out very wet. Rubber drain is off and little water cameout
When a washing machine drum is removed from the tub after it has been in service for a while a number of objects are often discovered - bra wires, buttons, underwear, coins...
It is possible one or more such items is partially blocking the drain inside the tub.
Sep 04, 2016 | Neptune Washing Machines
Washer won't spin
You need to check this part of you machine:
Test the lid switch
Test the timer control
Test the centrifugal switch
Test the water level switch
Inspect the motor coupler
Inspect the drive belt(belt drive only)
Inspect under the washer for soot (clutch)
Test the motor
Inspect the pulley
Test the transmission
Check this parts this are the some cause to not spinning.
Dec 10, 2009 | Maytag Neptune Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag mah4000aww, tub overfills
Have you changed your door latch wax motor yet... If you have the brown actuator pin then you want to chuck that wax motor out of there quicker than spit! You want the redesigned wax motor with the black actuator pin. I know of folks where the wax motor failure caused the timer and /or water valves to act up... See www.neptunewaxmotor.com for disassembly photos and other Neptune information.
Jul 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dear rxpert. I have washer Maytag Neptune Model MAH5500BWW Model 67787785ZH. After, The washer completed the Work, that still have water inside of washer (I hand to turned the basket inside the washer I...
This is actually normal. It is normal to have water between the wash basket (stainless steel tub) and the outer wash tub (plastic). There shouldn't be a problem unless the water is excessive enough to pool inside the wash tub itself or overflow onto the floor. You will always find a small amount of residual water between the tubs. Don't waste your money on a service call unless you absolutely have to.
Apr 10, 2008 | Washing Machines
I HAVE A MAYTAG NEPTUNE WASHER, MODEL NO. MAH4000AWW. WASHER WILL NOT SPIN OUT. WATER STAYS IN TUB. I DON'T KNOW WHICH PART NEEDS TO BE REPAIRED, COULD IT HAVE ANYTHING TO DO WITH THE CONTROL BOARD?
It is the drain pump and motor assembly that does not remove the water from the tub. Althought it spins, water is not sucked out of the tub. Try replacing the drain pump and motor assembly. Part no. 22003059.
I did and my washer works well now.
Bill P
Herndon, VA
Mar 30, 2008 | Washing Machines
Maytag Neptune MAH4000AWW
I SAY REPLACE TIMER (POWER CONTROL BOARD)
Jan 15, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
129 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
