Question about Sony KP-61V45 61" Rear Projection Television
Kp-61v45green flickers left to right
I replaced the convergence amps on this TV about a month ago and it has been working fine , but in the last two day the green starts flickering from left to right , the red and blue stay where they are supposed to be ...this trouble is different from when i replaced the amps so i belive it to be a a seperate issue.... any ideas?
    Genius:
  • 2,920 Answers
There is a convergence board in the back of the tv that needs replaced..my tv was doing the same thing and i rto be replaced the board and it works perfect now.the part should run under 100.00 and has to be soldered in place.
Posted on Aug 17, 2008
My Sony KP-46WT500 has a yellow arc of color on the upper left side that never goes away even with plug in devices like Wii. It started about 6 months ago and has gotten worse over time. What can I do?...
Very common problems,through out the DLP tv life cycles could happen again again until end of the tv life itself.The tv have a problems known as a convergence picture problems,it is dead.Tv have any colors lines like R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes?Than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The Shop will cost u like $300-350 for parts and labors.
Aug 03, 2011 | Sony KP-46WT500 46" Rear Projection...
Red is ghosting to the right. i replaced the convergence tubes about 6 months ago. went with the expensive ones "not the cheapy's" used heat sync putty stuff and everything. the problem is...
Yes,the tv problems it is the same,it is the tv convergence problems again,now it just color it is shaded in shadows pictures,instead of wavies mis colors R,G,B mis alignments.Yes.The tv convergence board it is the problems,must be repair again.
Apr 27, 2011 | Sony KP-57WS500 57" Rear Projection...
I have a Sony KP-57WS510 and am having problems converging. The red works fine however the blue cross on the outside colums of the convergence pattern is off to the left. I am unable to move these blue...
The tv convergence board it is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.U have all the tools and also can do soldering ICS works?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a complete convergence kit parts for ur tv model and repair it ur self.Or the tv shop,will cost u like $300-350 for parts and labors.
Apr 23, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
The left side of the picture has red and green stripes and ghost images. The right side does not have this problem, but the picture is not quite right. The convergence chips were replaced two years ago and...
That sounds like the convergence problem I had about a year ago, and like you, I replaced the convergence chips and that fixed the problem. It's cheaper to replace the chips if you do it yourself, but maybe not if you send it out for repair. If you can find an exact replacement board, that would fix it too, but I wouldn't necessarily expect it to last longer. The advice I read on replacing the convergence chips in my rear projection TV was that they would last 2 or 3 years and then need replacing again. So you're within that range.
Feb 27, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony HD Projection TV - Picture bent and seeing multiple colors
This is due to failure of convergence out ICs that need to be replaced in D board.
If you are comfortable with TV repair let me know to provide you technical info to fix TV.
Apr 17, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony KP-57WS510 Convergence issue?
Replace convergence IC's....STK392-560 X 2 + check pico
fuses under IC heatsinks.....................T.
Nov 12, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
The color keeps going out
The repair tech used cheap parts or did not replace both convergence chips.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Nov 12, 2007 | Sony KP-53V80 53" Rear Projection...
Problem
Hi three months ago my kp-61hs30 tv looks like 3d picture and technician man replaced the two convergence Ic's but last night my tv looks like 3d picture and it look like is the picture goes down
i don't know why happened again
Oct 30, 2007 | Sony KP-61HS30 TV
Hitachi 51f500(flicker+warp)
Most likely bad convergence IC's! Location numbers should be IK04 and IK05. Generic numbers STK392-110.
Jan 23, 2007 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
