Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Needed Fresnel Screen
I am looking for the sceen that goes that is on the out side. Please e-mail
  • twolle Mar 07, 2008
    i am looking for the 60inch one.
  • Philips Master
  • 8,617 Answers
What size screen? That model comes in 43,50 52 and 60 inch models.I have a source for the 43 and 50 inch models.
Posted on Mar 07, 2008
  • Sonny Berry
    Sonny Berry Mar 07, 2008
    Sorry we only have the 43 and 50 inch sizes,
Mitsubishi hdtv 1080 ws-a65 screen broke need replacement
there are 2 functionality screens and 1 screen protector (on some)
front screen = lenticular
back screen = fresnel
very front screen = screen protector (you can replace w plexiglass)
the fresnel and lenticular are very specific.. contact your local repair center for a new one. you can cut them from old screens but have to do just right (fresnel is a lens type - pic will be distorted if off center)
maybe find a old junker tv to pull screens from because new ones are about $100 a piece
Jun 03, 2010 | Mitsubishi WS-65311 65" Rear Projection...
My boyfriend was bringing our new 60 inch television home. he put a tarp over it and it scratched the screen. what can we do???
There is not much you can do besides replace the screen. Go to www.encompassparts.com There are 2 screens together on the front. The outside screen is the lenticular sceen and the inside screen is the fresnel screen. Thanks
Oct 29, 2009 | RCA P61927 61" Rear Projection Television
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
My screen is cracked.
Projection televisions have 2-3 screens that make up the screen assembly. A fresnel (closest to mirror) and lenticular (closest to viewer) make up the working components. A third screen protector may be on the outer side to protect the inner screens. Try to find out which screens are damaged to know what parts are needed. If it is just the front most, you could remove or replace with simple plexiglass. Always keep screens oriented as found and scratch and dust free (even an eyelash between them will show) for the best picture possible.
Dec 07, 2008 | Televison & Video
Mitsubishi screen replacing
You must remove the front bezel and frame holder to replace the screen. You will usually see the screws holding the from from the rear of the unit. Once you get the frame off, take note of the way the old screen is installed. There is usually a label on one side near the bottom; the new screens must be installed with the label in the same location. The lenticular goes on the outside (facing the viewer) and the fresnel goes on the inside facing the mirror. You will be able to recognize the fresnel, it has a series of concentric circles that are raised on the sirface of the plastic Be sure to rate this solution.Thanks!
Nov 08, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Help
Please check HERE for front screen of your Hitachi projection tv.
Oct 18, 2008 | Hitachi Televison & Video
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Sony KP-48S35 48/Broken Screen
The fresnel screen and the lenticular screen. The fresnel is part # 405845511 and is about $160 new. The lenticular is # 405845411 and is about $330.
Milford CT Real Estate
Oct 12, 2007 | Sony KP-48S35 48" Rear Projection...
I need to replace a broken screen on my sony kf 50we610
Hi drdoolittle,
Some screens have labels, so place them so the labels are upright and tward the front of the TV.
The outside screen is the lenticular screen. The black vertical lined side is outside. The fresnel screen has very fine circular lines in it. You can find them by feeling them. This goes against the lenticular back side of the screen. the fesnel has a flat side that is the back. It will be tward the mirror. If the mirror has two shiny sides, then it should be placed with the mirror side out. You can tell this by placing your finger tip on the mirror. If the finger nail meets a fingernail, then this is the mirrored side. Install this side tward the front.
Try to keep dust from between the screens. Check by looking through the screens before you put the in the frame. Then check them again after you put them in the frame.
Wear latex gloves to keep finger prints away.
Clean back of screen assembly and install the screen on the TV.
You can now watch the TV.
Cheers, CrazyLee
Sep 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Lenses
The screen with the "swirls" on it is the fresnel lens and that is the one that goes in back then the lenticular lens goes next (it has the feel of a grid to it). Then the screen proetector goes on the very front. The fresnel lens only works installed one way. On Sony TV's look for the orange tag with the part number on it and put that to the lower right facing outword and usually 99% of the time this is how they go back in.
Feb 18, 2007 | Sony KP-51WS510 51" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
83 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
