Direct drive washing machine will not spin already had new motor fitted?
  • Gary Davd
    Gary Davd May 11, 2010
    is the coupling ok??
CHECK LID SWITCH
Posted on Mar 03, 2008
THE SPIN CYCLE WILL NOT WORK ON ANY CYCLE THE PUMP WORKS BUT WILL NOT SPIN OUT CLOTHES PLEASE HELP
If you have a direct drive washing machine you need a new motor coupling. Do a search online with your make and model number and see if you have a direct drive washing machine. The motor coupler is 2 pieces of plastic and a rubber gasket. Its about a $20 part and depending on how mechanical you are, should take about 30 minutes to fix. There are a lot of website and videos showing how to fix step by step. Do a search online like: How do I replace my motor coupler on a MODEL NUMBER. Good Luck!
Feb 22, 2011 | Washing Machines
Hi my washing machine is working properly. The dial that you select the washing programme keeps clicking round so it doesn't spin or wash. You can hear the motor working and go through a cycle but the drum...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Nov 16, 2010 | Washing Machines
Kenmore model #23922 washing machine won't spin
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
May 14, 2010 | Kenmore Washing Machines
Will not spin,
Washing machines may drain but doesn't spin because of the following reasons:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
  • Thank You
    Jan 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
    Whirlpool Top Load washing machine no spin cycle
    Click here for more info on the direct drive appliances.
    Aug 28, 2008 | Washing Machines
    Whirlpool Ultimate Care II Plus Washer Model: LSQ9264HZ0
    if you hear the motor running while it is supposed to be agitating or spinning then it is most likely the direct drive coupling between the motor and transmission.43f18ab.jpg9bd1c44.jpg if you already checked this and think it is a different problem then let me know, i will help you figure it out.  Mike
    Jul 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    101 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
