Question about Refrigerators
Frost build up in freezer
I have frost build up in the freezer part of my fridge/freezer. it is a beko cda554w does anyone know how to stop this or am i doing something wrong?
  • geofflyo1 Nov 17, 2009
    have upright freezer , what can be wiped on the elements to stop the ice from forming or making it easier to remove , can anyone help me please
  • Gary Davd
    Gary Davd May 11, 2010
    you have a defrost problem
    Scholar:
  • 54 Answers
Be sure the door seal is secure and closing tightly to prevent excessive moisture infiltration.
Posted on Mar 04, 2008
I have a beko frost free fridge freezer its only 18 months old and Ive got a build up of ice in the fridge. all my food is getting frozen and Ive got my temp dial down to min .cant understand what cou
Is the door seal working correctly? If the door has become distorted slightly it might be letting in moisture via a gap in the door seal which will result in the build up in ice.
If you can see ice build up leading from the door area, this will give you a clue to where the seal may be faulty. Check that the door is squared up to the freezer with a spirit level and if required gently bend the door back into place by holding the corner with your feet and adjust from the other corner.
Oct 07, 2014 | Beko CDA670FS 280 litre Frost Free Fridge...
Fridge part of fridge freezer stopped working
Please add the make and model of your fridge. Is it frost free or not?
Jan 06, 2014 | Beko Refrigerators
I have a beko fridge freezer seral no0810452709 model cda554w is this one of the models recalled
The model number you have supplied doesn't appear to be in the correct format. Please see the information that follows.
I'm pasting this response on all queries regarding the recently announced issue with BEKO fridge freezers and the risk of fire from their defrost mechanisms, but I have placed it here in hints and tips too, in the hope it will be of use to any concerned BEKO Fridge owners:
According to several sources I have checked, including the London METRO magazine ( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall) The MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
From what Ican ascertain, the fridges affected were manufactured between January 2000 andOctober 2006 (So, after shipping and sitting around in shops, you can probablyextend that margin to machines SOLD between 2000 and 2008)
If you go to the BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
I have to say. Regardless of dates and matching serialnumbers, if I had an affected model,I would be checking with BEKO anyway!
Jul 05, 2011 | Refrigerators
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 | Freezers
Hi My beko frost free freezer has been building up ice in the little grid thing at the top of the freezer. The temperature was also driopping ( to 8) and so I have put it on fast freeze to raise temp. What...
check the door seal on the top of the door if not sitting flat to the frame it will encourage frost to build up (inside the little grid thing)which will stop the rest of the freezer from cooling enough.
Jun 14, 2010 | Freezers
Thick ice build up behind freezer fan
check door rubber,if is oblate heat it with fan,if it is ragged change it.
Jun 29, 2009 | Freezers
Our beko frost free fridge freezer has stopped freezing. The fan is working and the freezer section cold but not cold enough. Thermostat is in the fridge - the fridge is icing up.
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Aug 12, 2008 | Refrigerators
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Refrigerators Logo
586 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
