Question about Motorola Mobility MD481SYS Cordless Phone
Buttons do not work
My 481 cordless with extended handset. The ON button & Off button of both handsets no longer work. This has been the best phone we have owned, however Motorola Does Not repair this model and it has been discontinued. Is there a repair shop with a reasonable charge that can repair them or can I remove the case to try and clean the buttons ? or shall I just web search to find new ones.
SOURCE: Motorola 580 handset not working
are these phones registered to your base? scroll around in the menu until you come to register and press the "-" key. then quickly press and hold the page button on the base unit. you will here the phone beep. should work now
Posted on Mar 23, 2008
SOURCE: key pad on corless handset is not working
call Motorola they will replace the unit. I recieved four from them
Posted on Apr 03, 2008
SOURCE: md 481 cardless phone
Phone is most likely broken.
Look on Ebay for a replacement phone system or a good used handset.
Posted on Aug 14, 2008
landsend
  • 1066 Answers
SOURCE: Motorola Cordless phone
it isn't worth it fixing...replace it with a new phone.
Posted on Apr 01, 2009
Shiv_Jee
  • 87 Answers
SOURCE: Can't register Motorola handset.
There is a very little that we can proceed to here, as these phones are known for the problem that you are facing & most of the customers that I have myself seen ... finally get rid of them buying new ones,
Let’s try resolving it though;
1.) Open battery compartment, remove battery. Also remove belt clip on back of phone. You might have to pry it a little.
2.) Pop off the access panel on upper back of phone. This panel merely hides two screws.
3.) Unscrew all visible screws, Separate front and back of phone. You might have to wiggle the pieces relative to each other. The rubber strips on the sides are held in place with dovetail grooves.
4.) The phone should come apart in three sections.
5.) At this point, get some cotton swabs and alcohol. Dip a swab in the alcohol and rub down the contacts on the keypad and little black pads underneath each button on the rubber membrane.
6.) Let it dry and re-assemble. Your phone should now work properly.
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Posted on Aug 21, 2009
How do I link handset to base after power outage CS6529-3
You set the cordless phone back into the charging base. After a few seconds (longer if in need of a charge), the cordless will register with the base establishing the connection required to place and receive calls.
Feb 19, 2015 | Lands Phones
ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Aug 02, 2009 | Uniden DECT 6.0 Cordless Telephone...
Uniden handet does not work
If you have had phone for about a year, yes.
Mar 14, 2009 | Uniden DECT 6.0 Cordless Telephone...
Md 481 cardless phone
Jun 24, 2008 | Motorola Mobility MD481 Cordless Phone
Cordless phone EnGenius SN 920
. A new handset arrives with a handset ID number of 00, to register this handset to your system take the following steps:
  1. On the EnGenius base unit press and hold down both the "Volume" & "Intercom" buttons for about five seconds. You will hear a beep from the base unit. You can now release the two buttons.
  2. On the EnGenius handset (00), press the following buttons: "menu", "6", "1".
  3. A new handset ID number (ie: 12, 13, 14…) is automatically assigned by the base and registration is complete.
Feb 29, 2008 | EnGenius SN 920 Ultra Cordless Phone
Uniden cordless phones
This sounds like the register-deregister problem elsewhere on this page. Try holding down the "end" and "#" buttons for about 6 seconds to deregister the phones and then reregister them. I had this problem too and it worked for me.
Jan 19, 2007 | Uniden TRU8885-2 Cordless Phone
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
Handset Buttons Stopped Working - Full Battery
Here is a link to Uniden's site, and on the right side of the page, there is a link for a download manual pdf and helpline
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
also worth checking if any buttons are stuck, or if the handset is set to pulse rather than tone mode, or if it has had a tumble or knock, possibly the keypad connector has come loose .
Hope this helps.
Sep 17, 2006 | Uniden TRU8885-2 Cordless Phone
Motorola Mobility MD481SYS Cordless Phone Logo
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
