Question about Mitsubishi WS-55807 TV
My Mitsubishi WS 55511 died.
My Mitsubishi 55" TV died. No sound, no picture, nothing. It's dead as a doornail. Its only 4 1/2 years old. Any suggestions?
    Scholar:
  • 52 Answers
If you are lucky, it's only a blown fuse. Some tv's this large have more than one fuse, so look real hard and find all fuses. If fuses are good, then about 95% of the time, when you have no picture/no sound, the problem is a bad H.O.T. This is a large transistor with three pins soldered into the main board and is very easy to find because it is connected to a metal "heat sink". Look for a large red or black wire coming from the pic tube down to the main circuit board (sometimes it's blue, but it's the only wire coming from the GLASS part of the tube to the board. This wire goes to about the largest component on the board called the "flyback transformer". It is usually black and is about 3 or 4 inches tall, 2 inches wide, and 2 inches thick. The h.o.t. will usually be located in the area of the "flyback". The h.o.t. will be screwed with one screw or clamped onto a large piece of metal (usually silver). This piece of metal is usually about 2 inces square and is about 1/8 of an inch thick and is mounted perpendicular to the main board. Imagine a slice of bread standing on one side rather than lying flat and this is what the heat sink looks like. Sometimes you will see several heat sinks with transistors screwed into them, but the one you are looking for will always be the largest transistor with three pins. Don't forget to unplug the tv before you begin and stay away from the large wire coming out of the tube going to the "flyback". Do NOT unplug this wire from the tube. It can shock you very badly EVEN WITH THE TV OFF FOR SEVERAL DAYS. Just be careful and go ahead and give this a try. You can do it, and this is probably going to fix your set. If not, then replace the flyback transformer. The H.O.T. is about $10 or $15 and the flyback can be from $30 to $80. It is possible that none of this will fix your set, but you have about a 95% chance that it will and with such a big and nice and relatively new set, I would give it a shot. Keever
Posted on Mar 04, 2008
Tip
Reset Mitsubishi HDTV VChip Password
Bypass or Reset Mitsubishi HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Bypass Mitsubishi HDTV Front Panel Lock
Mitsubishi WS-55511 Manual Download
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Bypass Mitsubishi HDTV VChip Password
I hope that helps.
TV won't turn on
Do you have any lights on on the front of the TV? anything flashing? Or is it just dead?
Mar 21, 2013 | Mitsubishi WS-55511 55" Rear Projection...
The picture is bigger then the screen how do I adjust so that the picture is same size as TV thanks
Please confirm tv model number as question shows its Mitsubishi WS-55511 rear projection tv.
This info will help me to suggest a solution.
Do you get correct colors in picture though its over size?
Thanks.
Aug 13, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Download Mitsubishi WS-55511 HDTV Manual
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
9 year old TV...red shadowing. Is a bulb out?
No,this tv don't have a projection bulb inside,it used CRTS tubes like R,G,B guns technology.The tv problems u are having it is call convergence problems,it is dead.The tv convergence board it dead or dying that why tv have R,G,B colors lines misalignments,have colors shadows picture or have 3D pictures look alike.The tv convergence board must require changes like 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv picture convergence problems.The tvs Shops will cost u like $300-350 for parts and labors.
Jun 13, 2011 | Mitsubishi WS-55511 55" Rear Projection...
My Mitsubishi TV is about 12-14 yrs old. The
DLP projection tvs are bulky and have a design flaw in the convergence board the 2 STK convergence ICS alway dies constinely require replacement,if u use about 4 or 5 hours day in and day out.If the old Mitsubishi tv several years since is was repair,u use it alot?If yes,it time to retire it,and buy the refurbish Plama tv.Not,than get the old tv repair.U Know how to solders?Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.U can go to You Tube type in Convergence problems will see a tutoring video in repairing 2 STK Convergence ICS.
Mar 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi 55 inch-ws 55511
23 code means "loss of Horizontal Deflection"
Nov 14, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55807 TV Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
