Question about Dell 2200MP Multimedia Projector
Dell 2200mp projector
My dell model 2200mp was working fine then when used next day had blurred and out of focus projection. The focus would not work and wouldn't clear up. Any suggestions on what could be wrong with it?
  • Myron Loss
    Myron Loss May 11, 2010
    Do you know if anything happened to the projector, like being bumped, or falling off a table?
    What may have happened is that the lens has come loose inside the case and will not respond to the focus knob. Try moving the part of the lens ring outside and see if the lens appears to be loose.
Marrie
  • 563 Answers
SOURCE: dell 2200mp mounting screw
Hi wspy
If the look right next to the holes there should be a screw size written on the casing itself.
Posted on Apr 30, 2008
hashchathy
  • 246 Answers
SOURCE: Power Supply Unit of Dell 2200mp
first look at the dell site.
Then try to get your country dealer .
Before that contact your dealier
Posted on Jul 23, 2008
SOURCE: Dell 2200MP
Check that lamp cover microswitch closes (clicks). This microswitch disables the power supply when open. I had to bend the lever a bit to make it reliable.
Posted on Oct 11, 2008
SOURCE: Dell 2200MP Powers off
I have 2200MP projector that when you turn it on,it clicks about 8 to 10 times and then the power seams to turn on, but the lamp light light comes on and nothing lights up. it will shut down after that, with the green light still flashing. What could be the problem? Roger
Posted on Nov 23, 2008
projdoc
  • 2237 Answers
SOURCE: Dell 2200mp projector will not power up
if not even an led comes on, you need to replace the power supply.
Posted on Dec 16, 2009
Dell 2200MP lamp turns off
Check to see if the fan is working, It maybe getting too hot.
Dec 28, 2007 | Dell 2200MP Multimedia Projector
Dell 2200MP makes a loud Humming Noise and vibrates
even if a fan spins it still can be noisy.clean all fans (i use a tooth brush).i also buy air in a can..(poundshop sells them).and spray them to clear any dust.when you have done that start the projector and see if is sorted...
Nov 02, 2017 | Dell 2200MP Multimedia Projector
Dell 2200mp doesn't focus
Sounds like a servo motor thats broken (the electric engine moving the focus adjustment) If the system have manual focus it could be the connection between the focus ring and the "focus" thats worn out
Sep 07, 2008 | Dell 2200MP Multimedia Projector
Jul 28, 2008 | Dell 2200MP Multimedia Projector
Jul 23, 2008 | Dell 2200MP Multimedia Projector
Dell 2200mp mounting screw
Hi wspy
Apr 29, 2008 | Dell 2200MP Multimedia Projector
Remote control
First, make sure your batteries are good.
For moving the slides ahead, there is a button that says next page. When you push that, it will advance.
O, another things is that you must connect your computer to the projector with a USB cable. I assume that you are trying to run it from a computer.
Perhaps you could explain more about what you are using.
Mar 04, 2008 | Dell 2200MP Multimedia Projector
Dell 2200mp searching for signal
One problem may be that you must tell the PC to send the signal to the external monitor. Usually, if you hold down the function button and hit the F5 key you will see several options on the screen. (Other laptops use different function keys. Look for the one that shows two tv screens. You want the option which shows the laptop and the external monitor.) To advance between options, you hit the F5 button again and it moves over to the next option.
My computer needs me to lower the resolution on the laptop in order to send the signal to the projector. If you also need to do that, you can do it in Control Panel, Display, and Settings, and lower the resolution on screen number 1.
Doing both of these things should work.
Also, confirm that it is finding signals by hooking it to a DVD or video and see if it finds the signal through one of the other ports.
Sep 25, 2007 | Dell 2200MP Multimedia Projector
Dell 2200MP Multimedia Projector Logo
56 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
