Question about Minolta Maxxum 7000 35mm SLR Camera
The sprocket in my Minolta Maxxum 7000 will not advance the film trying to load new film. I just put new batteries in the camera, but it has not been used for a while. Any suggestions?
  • 667 Answers
The battery holders were known for corrosion buildup at the pivot point, your batteries might not be making good contact.
Posted on Mar 04, 2008
The camera isn't taking the picture
Batteries good? Contacts clean? If battery leakage clean and retest. Is the camera autofocusing? Did this start after you loaded film? Did the camera advance to 1?
Jan 18, 2014 | Minolta Maxxum 7000 35mm SLR Camera
I recently put film into my camera and it was all loaded up and working but today when i turned it on, it made this weird sound and then the film count went back to 0 and the word that said film was...
Try changing the film,I own a Pentax and experienced the same problem.I threw away the previous film and loaded it with a new one,it worked fine.
Thank You.
Feb 22, 2011 | Minolta Maxxum 7000 35mm SLR Camera
What year was the Minolta Maxxum 7000, serial number 16043985? Thanks, Karla
I do not know for certain. You might find that answer on the Yahoo Minolta groups.
The Maxxum 7000 was introduced to the US market in 1985. Sold as the Alpha 7000 in Japan and Dynax elsewhere, it was replaced by the 7000i in a couple years. Then the 700, the 700xi, the 700si, the 70 and the 7 was the last film based 7 series. There
They also made 8000i, 800si, etc. The 9 series was the Minolta Professional cameras and they had the toughest bodies, weatherproofing, higher shutter speeds, and more.
Later models introduced better autofocus, better exposure options, wireless flash, faster film advance, etc.
lightspiritphotography.com
Nov 10, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Loaded film camera will not work asks for program how do i do this How do I set the program on my Minolta Maxxum 7000
it might be the internal battery. remove the battery holder and remove the screws on the metal plate. gently lift the plate and replace the battery. remember the different length of the screws.
Oct 29, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Camera took pictures to # 7, then the 7 just blinks off and on, then won't do anything else. I put in new batteries, thinking that might be problem. It isn't/ what to do????
Likely its the film tranport motor. If that goes out, the camera cannot advance film. Try rewinding film. I forget if the 7000 had 1 or 2 such motors. Could also be teeth broken/worn out on the gears, but sounds like a trip to the repair shop is in order. If it will not rewind, put the camera inside a zipped dark jacket. Fold the bottom of the jacket to block light. Put your arms in the sleeves and open the camera back. Pull out the film, rewind it into the can.
Oct 16, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Is the Minolta Maxxum 7000 capable of using infrared film?
goneoutthewi,
once the shutter is closed or the shutter open and the mirror is up no light strikes the film except the image. don't forget to use the red markings on the lens as infra-red focuses on a different plane than visible light.
Mar 27, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 5000
I had the same problem with a maxxum 7000. Traced it to a bit of corrosion in the battery pack. It let just enough power through to run the computer, but upon releasing the shutter, it shut off.
You might check that. corrosion can be cleaned with vinegar.
-John
Oct 07, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 7000
ONline manual from Minolta says "winding motor problem", try removing battery and reinstalling. It didn't work for me though.
Jul 13, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Will not load film
Is the lithium positive side down?
Jun 19, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta maxxum 7000 troubleshoot camera wont take pictures
There are several possible reasons, it could be the body or the lens. Check the shutter blades without film. Are they smooth and in place, (flat)? It could also be related to the film, a mis-load of the roll. The lens could have some failure, possibly try another.
Jun 14, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
161 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
