Question about Jetway (V2MDMP) Motherboard
Primary IDE interface fails to load
When the power is disconect from the computor and reconected the primary IDE does not load if i move the hard drive to the secondary and the cd drives to the primary it will then load,
or if i just use the reset button and not switch the hard over it will load as long as i do not remove the power suply
  • delboy1962 Mar 04, 2008
    thanks for your help the reset is not the problem as it does as it should,
    its not a new board its a problem that has developed,
    i have two hard drives and two roms,
    primary drive hard drive one and two (master & slave) if you disconect the power suply and reconect it will not get past IDE detection stage it locks there then press the reset button and it boots fine,
    if i put the two hard drives on the secondary (master & slave) it all boots ok and also the primary does reconize the two cd & dvd roms
  • 152 Answers
Many new motherboard does not recognize slave mode on if single ide drive connect
verify both drive set is master or not after that you attach to primary your harddrive and secondary cdrom
your reset problem is wirering connection see your motherboard manual
Posted on Mar 04, 2008
Primary slave drive fails
Go into the BIOS and make sure you are trying to boot from the Primary Master Drive first. If not, move the Master Drive to the 1st boot position.
If the above fails, you could just remove the power cord, remove the case and notice how the two drives are connected and remember it. There will be one cable that provides power to the drive from the power supply on each drive. Also, there might be one cable that connects both drive, or there might be one in each drive, etc. I would disconnect the power and cable on one of the drives and try rebooting. If it fails and you have one cable that connects both drives, try the other cable connection and reboot. If it still fails, then I would try doing the same thing with the other drive.
If all the above fails and your system has the IDE (whereas the cable has about a 2 inch end with about 20 holes that plug into the 20 pins on the hard drive) interface, remove the drive to check and see if the little pin on there along is set to Primary, Master or Cable Select. Normally on a two drive system they will be set to CS for Cable Select and the IDE Cable based on how it is plugged into the drives determines which is Master and Slave, but older systems might have the Master and Slave setup.
Apr 09, 2012 | Sony VAIO Digital Studio PCV-RS410 PC...
The power light is on, it isn't running, and it is not connectiong to my computor. This has all my kids pictures on it.
External hard drives of this type are mainly composed of a USB-to-SATA interface & a 2.5" SATA hard drive. If any of these components is defective, then you won't be able to access your data.
So, basically we have 2 possibilities:
1. A failing USB-to-SATA interface. You can test this possibility by disassembling the device, taking the hard drive out, & testing the hard drive in your desktop computer using a 2.5" to 3.5" SATA adapter. If the hard drive works fine, then the problem lies within the USB-to-SATA interface.
2. In the previous step, if the hard drive could not be detected by your desktop computer or is not working properly, then it is the failing part.
Aug 31, 2011 | SimpleTech Computers & Internet
What type interface does my sony PCV RS520use for my DVD Burner ?
Since your hard drive uses IDE, so will your CDROM.
There are normally two IDE interfaces, with each interface having a primary and secondary connection (total of four connections, 2 on each).
You hard drive would be connected to the primary connection of the IDE interface 0, and the CD/DVD Rom would be connected to the secondary connection of the IDE interface 1.
Here is a link to some manuals you can look at in PDF format.
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=PCVRS520
Feb 22, 2011 | Sony VAIO PCV-RS520 PC Desktop
Received Dell XPS 8100. No cd player so they sent me one. Dell hell it is. Anyway, I opened it and found MANY wires unconnected. Can you tell me what connects where? I took the cd burner out of my old one...
Your old computer had IDE interface, the new computer has SATA interface.. There is a thin connector power cord and interface cords with tge same width connectors.The existing hard drive has thes cables connected to it. Connect one power cord and one data interface cable to the cd drive. Connect the audio cable to the cd drive and the Audio IN connector on the motherboard.
Unless the motherboard has a ide connector. you can not use your old hard drive or cd. You can get a external drive encloser that can convert IDE to USB
Oct 14, 2010 | Dell Studio Xps 8100 Desktop Computer
Primary IDE port does not work on intel d865GVHZ motherboard
we are repiar the mother board and 100% warrnty contect for more detetil : www.compudesk.in E-mail: support@compudesk.in
Oct 12, 2009 | Intel D865GVHZ Motherboard
Primary IDE port does not work. My main hard disk drive and DVD writer drive are connected to the Secondary IDE port. If I move them to the the Primary IDE port, both the drives do not get detected at all....
Good day sir, there are several way to connect an extra IDE if the motherboard is full:
  1. Buy a PCI to IDE/SATA card. Check your local computer dealer if there is available.
  2. Buy an external USB to IDE Hard disk enclosure.
Of course, these are things to buy, but check first the CMOS setup if the Primary IDE is enabled on your PC.
[Repost] Can't start windows
Ok i had the same problem today:
firstly check to see if the HDD is on its own IDE channel (ie. not sharing with another IDE device such as a CD-Rom or DVD drive)
if yes disconnect the Optical drive or other device on the IDE channel and boot and if it still isn't working change the IDE interface used if this still doesnt fix the problem.
Boot with the Windows Install CD and see if you can do a system repair / chkdsk , if the HDD is still not detected you possibly have a problem with your motherboard / HDD
to determine if its the hard drive if you have another HDD spare which you can try boot off give that ago and if it succeeds your other hard drive is failing time to get a new hard disk.
If you still have no success time to look for a new computer or get it changed under warranty if you still have it ?
Aug 18, 2008 | Dell Latitude CpX Laptop PIII 500 Mhz...
I need Help
Hi Banyar, lets check the main menu & the boot order in you're bios. Start up the PC, as soon as you see any display on the monitor press the delete key every 2 seconds until the bios main menu loads. This is also where you can see the time & date. List on the left is;
Primary IDE Master
Primary IDE Slave
Secondary IDE Master
Secondary IDE Slave
Across from these on the right is the matching device. If you have one hard drive the bios will show its model number on the right.
Ex: ST150322A. (You're drive will be different). If you have more than one hard drive the second drive, (Should be listed as Primary IDE Slave). CD-ROM drives would be listed as, Secondary IDE Master & Secondary IDE Slave. Write down the model name of the Primary IDE Master on paper. Now go to the title, "Boot" in the bios. Use you're manual & go to page 2-25. High-light, Boot Device Priority & press enter. Set the order as shown in the manual. Make sure the 3rd boot device is set to the correct hard drive listed from the main menu. The model you wrote down. Once set save & exit the bios. The PC will restart. You should no longer receive the error message & windows should boot normally. If windows does not load normally than it is possible that the Primary IDE master drive is not the drive with windows installed on it. You must find the correct drive with windows loaded on it. Connect that drive to the Primary IDE master port.
You may need to reset the drive’s pin settings so it is seen as the primary drive.
Than change the 3rd device in the bios boot priority list with the correct drive. Windows demands that the operating system be located on the, Primary IDE master port. Please read pages 2-12 & the top of 2-13 in you're manual.
More questions? Post them here.
Good Luck!
Mike
Jun 21, 2008 | ASUS P5VD2-MX SE Motherboard
Move hard disk from one pc to another with same file permission
hi..
if u want to move the hard diskk..
make sure the hard disk jumper is set primary...
and plug-in onto primary ide master or ide 1
good luck..
happy trying
tq
Apr 17, 2008 | Computers & Internet
Jetway (V2MDMP) Motherboard Logo
98 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Iqbal Husain
Iqbal Husain
Starnley Johnwells
Starnley Johnwells
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
