Question about iLO MP3 Player
Red 2 GB MP3 player
My player will play only on the usb port through the computer, will not power up with the battery. The battery has been changed, battery taken out for a while, left running on the computer for quite a few hours to see if it would power up with the battery and none of it has worked. Any help out there?
  • 8,596 Answers
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Sep 07, 2008
Does the iriver e200 need a battery change
All MP3 players need their battery charged before you cam play music.
You charge the player with the supplied USB cable when it is connected to the USB port on a computer.
Jan 27, 2013 | iRiver E200 (8 GB) Digital Media Player
SanDisk Sansa Express 2 GB MP3 Player (Black), battery status states 14% critically low....what does it mean and what actions should I suppose to do?
You need to charge the battery so you can continue playing your MP3player.
Connect the supplied USB cable into the player and then plug it into the USB port of your computer. The computer will charge up the MP3 player and you can also copy mp3 music and photos etc to the MP3 player.
Aug 25, 2011 | SanDisk Audio Players & Recorders
MP3 Sansa Sandisk 1 GB
If it won't charge, then:
1) USB connector is damaged
2) USB port is damaged (Have you tried other port and/or other computer ?)
3) MP3 Battery is damaged
May 27, 2009 | SanDisk Sansa m240 MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
MP3 Player Not Charging!!! (USB)
The most common cause is a flat battery. There is a trick to charging
the battery in these small mp3 players. It wont charge if it is turned
on, and it won't charges if it's in sleep mode (zzzz). Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje player on
3. turn it off by either holding down the play button, or selecting
"System" from the menu
4. The screen will go black and the battery will begin charging.
Feb 15, 2009 | Coby MP-C7092 (2 GB) MP3 Player
Samsung yp t9j Media Player (2 GB)
This mp3 player and many others do not play or do anything on screen besides charge WHILE it is connected to the computer. You can transfer songs to the player while it is connected to the PC. After it is disconnected, then you can play songs.
Nov 09, 2008 | Samsung Yepp YP-T9 Digital Media Player
Only Plays 20% of songs
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 04, 2008 | iLO (2 GB) MP3 Player
Ilo freezes
Nov 02, 2007 | iLO (2 GB) MP3 Player
Powering on and off
Aug 24, 2007 | iLO (2 GB) MP3 Player
20 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
