I have a samsung subwoofer that has 2 "red and black" or pos and neg inputs on the back and thats it, no volume knob or anything. I have found at radio shack a cord that lets me plug in at pos and neg and then plug into my receiver as a "prong." I still have no sound. whats the problem?
  • Riddler83 Mar 03, 2008
    There doesnt appear to be a cord to plug it in with, just the 2 red and blakc inputs on the back and i dont think i can take the face plate off. The model type is samsung PS-WTX72
    the receiver is a yamaha and is very nice. Well, it was in tis hay day. The model is RX-V659. What exactly is a subwoofer receiver? how would i use it or get one? The subwoofer is not plugged into anything than the wires going from the woofer to the receiver, and there is no power cord comming from the woofer
  • 788 Answers
The sub woofer most likely needs to be powered, is it also plugged into the wall? Otherwise it's not receiving an amplified signal strong enough to move it's diaphram.
Posted on Mar 03, 2008
  • Dean Joly
    Dean Joly Mar 03, 2008
    Then you need an amplified output on your receiver. If it's a inexpensive receiver or part of a home theatre in a box kit then it probably doesn't have one. MOST subwoofers are powered and the signal comming from the receiver has very low power.
    Another option would be the connect some kind of subwoofer amplifer between the receiver and sub. You would need to know what the wattage is of the sub and find a suitable amp. I looked around the web and that doesn't seem to be a very popular item. :-(
    Sorry! I take it the sub didn't come with the receiver then.
  • Dean Joly
    A subwoofer amplifier is a device that would amplify the subwoofer signal from your receiver to a stronger signal that would drive your subwoofer. Kinda like the ones used in car audio. I have never seen one of these as the amplifier is usually always built right into the sub. Speak to someone at your local stereo shop, they may be able to point you toward an amplifier. Like I said I didn't see anything on Google so they might not even exist.
How can I connect Bose 901 (speakers) to Sony STR-dh 520?
If you're using them in front then connect them via 2 wire (16 gauge or 14 guage) speaker wires to the back of the Sony unit. They're labeled left / right (as you would see speakers from the normal vantage point.) and front or rear. Make sure you get the pos/neg connections right. These are collored red (pos)/ Black (neg) on the sony and I believe they're red/black on the back of the bose speakers as well.
Feb 24, 2016 | Bose Audio Players & Recorders
I have an urban audio works 7 band equalizer. i have a spx pro audio amplifier and an alpine cd reciever model cde987. the equalizer is not installed. could your please tell me where to wire in the blue,...
INPUT: Yellow (left front), violet (left neg), green (left rear), Blue (right rear), Brown (right neg), Gray (right front)
OUTPUT: Front Left pos (green/red) neg (green), Front Right pos (gray/red) neg (gray), Left Rear neg (brown) pos (brown/red), Right Rear neg (white) pos (white/red)
Mar 14, 2011 | Car Audio & Video
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
Have a 2000 gmc sierra ext cab pickup and two type R swr-1042d subs and would like to know the best enclosure for the subs to get maximum performance and the best ways to hook up a one channel mono alpine...
it depends on the amp what can it handle. will it do 2 4 or 8 ohm is it 1 ohm stable are the subs dual 2 ohms or dual 4 ohms. 1042s are dual 4 ohm subs so if you wire them both in paralel it will drop both subs into a 2 ohm load for each sub that is pos of one coil to pos of sec coil then pos to pos on amp and same with neg to neg to neg on amp. now if your amp is 1 ohm stable i would do both subs the same way you will get the most power out of the amp. but itll run a littl hot if you dont have adaquate power running to the amp. now i wanna think your alpine amp maybe only 4 ohm stable. i would run both subs like i had said pos to pos then neg to neg now both subs will be a 2 ohm load so what you do to bring it back up to 4 is you run the 2 bridged subs into a series which is pos from one sub to neg of the other sub the remaining pos and neg will run to the amps pos and neg. which will make it into a 4 ohm load. now the last scenereo is your amp is 4 ohm or 2 ohm stable. this is how to wire it to 2 ohms and not 1. take one sub go pos to neg then pos to pos on amp and neg to neg on amp this will make an 8 ohm load with one sub take other sub and do the same neg to pos on sub then pos to pos on amp and neg to neg on amp this will tell amp to run a 2 ohm load. 2 ohms is a good run for these subs if the amp can handle a 2 ohm load. now if you would have given the amp model number i could have looked it up to just give you what you needed but with this short info i gave all possibilities.
Apr 20, 2010 | Alpine Type-R SWR-1042D Car Subwoofer
8 wires on my subwoofer??
"One has positive and negative input, another positive and negative output (red and black on each)"
Just from your description, it sounds like pos/neg input are the 12 volt pos neg supply for the amp inside the subwoofer. Red is pos, black is neg.
"positive and negative output (red and black on each)"
This sounds like it's used if you want to proved 12 volt pos/neg to another component.
"and a third wire with left input right input positive and negative (blue, red, yellow and black)"
This is for the cables coming from the "subwoofer out" on the amp. This is 4 wires altogether -- correct?
May 08, 2009 | Audio Players & Recorders
I cant figure out the rear speaker color codes on my 1996 pioneer deh-p725 car cd player, could someone help me?
green------drvrs front
grn/black--drivrs front neg
grn/red------drivers rear pos
blk/grn-------drivers rear neg
grey pass front pos
grey/blk---pass front neg
grey/red---pass rear pos
blk/grey---pass rear neg
Jan 25, 2009 | Car Audio & Video
How to wire my kicker solar baric
All depends on your amp. Is it 1 ohm stable or not?
positive (pos) on voice coil 1 (vc1) to Pos on vc2 and negative (neg) on vc1 to neg on vc2. Then speaker wire from amp to one vc only = 1ohm load.
Pos from amp to Pos on vc1. Neg of vc1 to Pos of vc2. Neg of vc2 to amp = 4 ohm load.
Jan 21, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
What is the colours for the wiring system for subaru legacy 94 for the amount of 14 wire's
above is link to wiring for 94 legacy , yet another source has a different layout , make sure the colors match your vehicle , 2 sources provided .
yellow/red = hot in on - fuse 17 -15amp
green = interior lights
blue/red = hot all times , fuse 25 - 10 amp
black = ground
yellow/blue = interior lights
black/green = power ant.
red/yellow = right fr neg
brown/white = left fr neg
white/red = left rear neg
blue/yellow = right rear neg
white/black = right fr pos
green - left fr pos
red/black = left rear pos
red/white = right rear pos
Jan 01, 2009 | Car Audio & Video
Neg and a pos on each side of car speakers
Depends on your amp. If they are dual 4 and your amp is 1 ohm stable and you have 2 subs, wire red to red and then red to plus on the amp. If your amp isnt 1 ohm stable wire ch1 red to + on amp, ch1 black to ch2 red, then ch 2 black to - on amp. If this sounds like french to you, go to a stereo shop in your area and pay them to hook up your stuff. It will be a lot cheaper than buying a new amp and subs.
Dec 18, 2008 | Digital Audio DA8012 12" Subwoofer Car...
612 people viewed this question
