Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Scanner locked after disassembly, cleaning scanner mirrors & assembling again, gtting "scanner locked" message
Also found that if you look down on to the scanner glass below it there is a blue plastic indicator showing if the scanner is locked or not. The adjuster for this is in the paper-out area so can get knocked by somebody grabbing the paper.
Just pull the blue switch towards you so the indicator is on the unlocked padlock, then turn the unit off and back on and that might fix it.
Posted on Mar 17, 2008
    President:
  • 2,072 Answers
Is the scanner latch in the down position. Would be on the right side of the machine.
Take the covers back off and disconnect and reconnect all the connectors again. The ribbon cables can be fickle and take 2 or 3 attempts to get seated properly.
May need to take the scanner back off, reconnect everything and make sure nothing is caught or binding.
Make sure you didn't somehow leave one connector unplugged, slipped behind something.
And during reassembly. You may have caught one of the harnesses or cables and damaged them. those on the right side looking from behind.
Posted on Mar 03, 2008
Not printing magenta
just remove the toner and shake it and install it if it is empty then install new toner.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 20, 2010 | HP Color LaserJet 2600n Printer
HP Laserjet 3330 Multifunction monochrome printer,copier,scan and fax. This machine will warm up, and after it reads "scanner lamp warming", the scanner lite lights up, the carriage moves back and forth,...
This type of problem is usually caused by dirty mirrors in the scanner. After a few years of use the mirrors and lenses in the unit will get a fine coating of dust particles on them. The dust interferes with the scanner initializing the optics. When this happens the unit displays the Scanner warming up message on the screen and keeps trying to move the scanner assembly to get a good reading from the pickup. To solve the problem you will need to disassemble the scanner portion and clean all of the mirrors with window cleaner and a soft cloth or q-tip. To get dis-assembly guides just do a google search for the 'scanner warming up' error.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 04, 2010 | HP LaserJet 3330 All-In-One Printer
When i start the printer, after the intilisation it starts clinking and all lights flash with message that there is fault in the scanner. How do I fix this?
This is a problem in scanner section on your printer.You need to disassembly the printer and pull out the scanner section.Open the cover of scanner section and you'll see the mirrors inside.You need to clean the ash from these mirrors using cloth which leaves no hairs.
WARNING! If you don't have a technical skills don't try to do anything.
If this not help you need to replace the scanner section.
Nov 12, 2009 | HP PSC 2175 All-In-One InkJet Printer
Message "scanner failure" on startup, makes noise while trying to work at startup
Oct 29, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP C6180 Scanner Failure error message
You need new scanner section but try first to clean this one.Disassembly the printer and pull out the scanner section.Open it cover and inside you'll see the mirrors.Clean the ash from mirrors using cloth which leaves no hairs.
Oct 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP color laser jet 2840. During initial power up/calibration, scanner bulb starts to click (and flash on one end), screen goes blank. Many people report similar problems. Some say it's a problem with the...
If the equipment shows the message "Scanner bulb warming up" and not initializes, look resolve:
Well have to clean the scanner assembly. Contains about 4-5 mirrors. It is very difficult to disassemble, careful to clean.
From here you can get service manual. There are 6 parts. put them all in a folder and a unzipp the first.
http://eserviceinfo.com/downloadsm/34029/HP_2820,2830,2840.html
Oct 09, 2009 | HP Office Equipment & Supplies
Scanner failure
You can fix this in home only if you can disassembly the scanner section.Open the top cover and remove the scanner glass. Then you must remove the scanner section.Open it cover and carefully clean the ash from all mirrors.Then assembly everything and scanner will work again.
Oct 07, 2009 | HP PSC 750 All-In-One InkJet Printer
51.20 error message on HP laserjet 4250n printer
It is an error with the laser scanner unit
1 Press ( SELECT button) to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and dc controller
PCA (J83 and J84).
4 Replace the laser/scanner assembly.
See Laser/scanner assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
If nothing from above works and the printer is no longer in warranty, it is possible if the printer is being used in a very dirty or dusty enviornment that the lens and optics of the laser/scanner are so full of debris that the beam detect error occurs. You can remove the top cover and the big black box in the center is the laser scanner assembly. Remove the screws securing the top cover of the laser scanner and remove and clean up all the optics to include the main mirror in the front. I usually use a damp q tip and for the mirror I slide up from toner cartrdige shutter area and observe from the top as it cleans the mirror. Removing the complete assembly on this model is not easy since there are a couple of cables going to the dc controller which are difficult to remove so removing the top of the assembly is easier.
Here is the service manual:
http://www.feedroller.com/Store/Service%20Manual/LaserJet%204250-4350%20(%204200-4300)%20sm.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 26, 2009 | HP LaserJet 4250n Printer
Scanner bulb stuck on left after mirror cleaning, machine frozen
The scanner is locked. You need to see the user manual and look for the scanner lock. It just needs to be switched to unlock.
Feb 12, 2009 | HP LaserJet 3330 All-In-One Printer
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
465 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
