Question about Philips 230W5VS (Silver) 23" LCD Monitor
Not powering on
It's not powering on at all.. seems like dead... I tried to open it to check some basics but wasn't able to open. Any docs on how to open this monitor?
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After that, you need to check if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Mar 04, 2008
Vhv680f hoover tumble dryer not turning on
-There are couple thing cause this problem.
Here try this if you are basic repair person.
-disconnect main power.
-Open back panel cover.
-Check all thermal fuse. Possible 3 (if open replace new one)
-Check heater element. (If open replace new one)
-Check door switch. (If open when door is open, replace new one)
*If every thing is good. How about the timer switch. Dial to on position and check continuity. If open replace the whole assembly.
-You can t get these part from difference places like
-Part appliance, Reliable part or Amazone.
Good Luck\
Mai
Dec 20, 2013 | Dryers
Once i opened my beac tv, it automatically turn to standby mode. there is a red light indicator. what seems to be the problem?
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to solve the problem...
Aug 09, 2011 | Televison & Video
TV wont turn On, standby light blinking 3 times, Help !!!
Good luck in solving the problem...
Jun 16, 2011 | Sony Televison & Video
Tv light flashed and cut off . turned back on and green light turned red and blinked 6 times pause then 6 blinks etc... tv will not power on. checked lamp seems to be ok. checked power supply board and...
Your power supply board is not yet dead, u know basic electronics' and soldering? You have to open the back cover of the television check for dry soldering on the printed circuit board , if found resolder but if not Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem...
Nov 29, 2010 | Televison & Video
My hp monitor is totally black it was working last night. i tried to unplug and replug it in and it came on for a few seconds then went black again
A lot of time people have the impression that the monitor is not working when in fact the computer is not booting its lighting up but nothing else so its stays on a black screen.
One way to know is by opening your speakers or plugging head phones, if you hear windows open or any windows sound the problem is the screen.
You can also unplug the screen from the pc and turn the screen on most of the time the screen while show a disconnected warning on the screen if that comes up the computer is defective.
Oct 29, 2010 | HP Computers & Internet
MY TV TURNS ON FOR ABOUT 3 SECONDS AND GOES OFF BY ITSELF I JUST REPLACED THE POWER BOARD BECAUSE IT WASN T TURNING ON AT ALL
This problems,the Tuner board is also dead,sometimes both power board and the Tuner board are dead.Replaced the Tuner board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Sep 08, 2010 | Vizio GV46L 46 in. LCD Television
The power supply on my VW22L HDTV LCD TV does not seem to be working anymore. The red light will not turn on when it is pluged in. Any way to fix it?
Open it up and take a look at the filter capacitors. They look like little oil silos or whatever. If any of them have visible holes or seem to have a puddle of brown-ish or black residue around the bottom, then they're blown out and need to be replaced. If not, then you'll have to take them out and test them with an LCR bridge to tell if they've changed capacitance. If the capacitors are fine, then check the voltage control IC, which is normally both soldered and held in with a screw against a part of the frame or a transformer. Again, if there's a hole or any melting going on, then that's totally fried.
Jun 05, 2010 | Vizio VW22L 22 in. LCD HDTV
Lenovo R61 Dead
The power supply in most computers has a fuse, either internal or external, that can blow without you noticing. Basically, you've been on battery operation this whole time, and the battery's finally gone dead.
It will be necessary to open the case and examine the power supply section. It may be possible to replace the fuse yourself, but any operation of this nature that involves opening the case will void any warranty you may have.
Sep 06, 2009 | Lenovo R61 T7300 Notebook
I want to open a jpg and doc file through command button in vb6
try to convert it to vb6 file and open it via vb6.... heres the link >>>> http://3d2f.com/tags/vb6/converter/registered/software/
Feb 28, 2009 | Microsoft Visual Basic 6.0 for PC
Random Shutdown
have you checked for viruses - specifically macro viruses in Word? Can you open your document using another/alternative editor? Does it happen in a specific doc or just a particular doc/s? Another way you can check assuming you can still open Word - try bringing up the MS Visual Basic interface (alt-F11) when you open Word. Check if there are any modules/macros active - don't forget to also check on the normal.dot template (known to be infected by some viruses historically). Another way to go is to completely uninstall and re-install Word. This assumes that your program is bad and not the doc.
Nov 15, 2006 | HP Pentium III , 1000 MHz Processor
Open Questions:
How do I fix my Toshiba laptop? Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 25, 2018 | Toshiba Computers & Internet
See all Philips 230W5VS (Silver) 23" LCD Monitor Questions
Philips 230W5VS (Silver) 23" LCD Monitor Logo
174 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
