Question about Lexmark Color JetPrinter Z42 InkJet
Lexmark 1270 All In One Printer, Scanner, Fax
Print clear does not clear......document prints and then shows "deleting" in status...........only way to clear is to restart computer. Operating system is XP..Have uninstalled and installed. Have downloaded drivers from Lexmark. Get the run around with Lexmark technical help in India..............
  • jozsan Mar 03, 2008
    I agree with your analysis of the problem, but are you telling me that there is no way for the queue to clear systematically after the document prints?
    I guess I would not consider re-starting, disconnecting, turning printer off and/or unplugging printer a "solution".
    I don't quite understand how your operation works. I am getting emails from you and "the machine". Should I be following instructions from you or am I expected to choose the recommendation that I think is best? Since I signed up for this service because I didn't know what to do, I am not sure I can make an intelligent decision as to what to do next.
    Master:
  • 788 Answers
Click start then run
type cmd and click OK
type: net stop spooler
hit enter
type: net start spooler
hit enter
This should clear your print queue without having to reboot your computer.
You could even create a batch file to automate this:
Create a new notepad document and rename it to clrspool.bat or something. Make sure to remove the .txt from the new file, Windows should complain about changing the file type. Open the new file with notepad (Right click it and pick edit). Add the two following lines then save and close the file:
net stop spooler
net start spooler
Just double click the file whenever your print jobs don't clear.
Posted on Mar 03, 2008
  • Dean Joly
    Dean Joly Mar 03, 2008
    The problem is most likely not Windows but the printer, it's not notifying Windows that it is done with your document. Maybe Lexmark has a firmware upgrade for the printer that may help.
    If you open up the printer's properties and pick print directly to the printer on the advanced tab that may help but this will slow dows your computer while you print. Also verify the other settings on the advanced tab to make sure hold mismatched documents and keep printed documents aren't checked. You could experiment with the other settings on the advanced tab and even change to a different print processor. Winprint->RAW is the default in case it has been changed.
  • Dean Joly
    Dean Joly Mar 04, 2008
    It is entirely up to you who you believe. It's is whom ultimately gives you the working solution that should give get highest rating. When I offer a solution I try to be thorough and complete, I put the same amount of effort into my solutions as I do in my job (which is in the IT field).
    My best solution for you would be to reload windows fresh on your computer and install the printer in the exact steps as laid out by Lexmark but that is much more difficult and time consuming than creating a batch file to run every time you get a stuck print job. Only after reloading Windows would you know for sure if your printer is causing the problem Otherwise you could lend your printer to a friend to see if the problem would eventually reproduce itself.
    In the end it is up to you and only you have the choice to tell any expert to no longer provide their assistance.
  • Lexmark Master
  • 19,396 Answers
I suspect it is because the print buffer in the printer is not being flushed properly and the document is sort of getting hung in limbo between the computer and printer.
the only way to clear cue is either re-start, disconnect the printer from the computer, or turn the printer off. Sometimes you may need to unplug it as well.
  • 2 more comments
  • Ginko
    Ginko Mar 03, 2008
    This normally is not a malfunction, it can happen on any computer depending on printing prcess involved .
    regards
  • Ginko
    Ginko Mar 03, 2008
    Sometimes there is no way to clear printer que with a click of mouse, because the process keep hanging between printer and PC, or spooling process is not responding or other. It is a bag of how spooling process works.
  • Ginko
    Ginko Mar 03, 2008
    Well, you can use a printer manager, like the one in this link. (it is a pay for software, I do not know any freeware one). Or you can force the spooler to close from windows cmd, as illustrated by the machine, or try changing printer. But often the fastest solution is turning printer off etc.
    regards
  • Ginko
    Ginko Mar 03, 2008
    Instead of dealing with this through emails, use this page
    http://www.fixya.com/support/t424300-lex...
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
Print jobs go straight to status "Deleting"
u check ur printer first.
how to check printer?
answer : u change ur os to winxpsp2 or win 7
and try again
if any assistance please mail happy.madathara@gmail.com
Jun 01, 2010 | Lexmark Z1300 InkJet Photo Printer
Epson All in One CX4800 with Mac OSX 10.5.8, printer hooked up, can print test page but no documents that are sent to printer print. Document never shows on status. Have tried reinstalling driver a few...
Go to System Preferences, then Print and Fax. Highlight the printer and click (-) sign to delete printer. Then click (+), highlight the printer and click ADD. Try printing again.
Apr 27, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Overheats when printing pictures on transfer paper and now it will not print anything.
hi
i have problem with my brother prinetr MFC-8460N
IT SHOWS DOCUMENT JAM
ALSO MESSAGE ON SCREN
CLEAR THE SCANNER JAM THEN PRESS THE STOP KEY
STATUS SHOWS RED LIGHT
WE ARE NOT USING SCANNER WE ONLY USE FAX AND COPY
RIGHT NOW BLUE LIGHT IS ON FAX AND WHEN I PRESS COPY BUTTON IS NOT ALLOWING ME
PLEASE ADVISE
Nov 10, 2009 | IBM Infoprint Color 1357 Led Printer
Printer not printing documents in que
my printer hp psc1315xi all in one printer copier, scanner will not print any documents, not even a test print, there is also a doucument in it that am not able to delet from the printer
Jan 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
Deleting Files from spool after they have printed
see your Spool settings, Set Print directly option and try.
Apr 09, 2008 | Lexmark X6100 Flatbed Scanner
Problems deleting printed files from the spool
Navigate
Start-> Control Panel -> Printer
Right click on printer icon and select properties
Find out Advance settings. See Spooling, Select Print Directly and try.
Although your driver looks like incompatible but above will fix your problem.
Thanks
Iqbal
Document printing hangs at 99%
same problem. everytime i restarted my pc and deleted the printed files from control panel/printers/lexmark x5150.
Dec 18, 2007 | Lexmark X5150 All-In-One InkJet Printer
Print web page
Sounds like maybe you do not have the Lexmark as your default printer.
Try choosing Print from the File Menu. Then you should see a list of printers and select the Lexmark.
If that doesn't work, try printing from another application like WordPad to make sure the printer can print at all.
If you still can't print, make sure the printer is online. Click on  Printers and Faxes in the Start Menu or the Control Panel. Then double click on the Lexmark printer icon. Make sure it doesn't say "Use Printer Offline" or "Paused" or anything like that in the title of the window that comes up. If it does use the Printer menu to change it.
Oct 09, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark Color JetPrinter Z42 InkJet Logo
190 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
