Question about Sony KP-61HS30 TV
SONY KP-61HS30 About 2 weeks ago the color on my tv went crazy, it looks like a 3D tv, now the unit won't turn on, the red light keeps blinking. What should I do?
Mine also looks 3D and warped. However, it will still turn on. Although I still am searching for a solution, a temporary fix is to put on 3D glasses and close your left eye.
Posted on May 31, 2008
    Novelist:
    Champion:
  • 203 Answers
Sounds like it needs convergence chips. This repair requires test equip. and soldering/desoldering tools. Most repair shops charge between 200.00 and 400.00 to do this repair on your model of tv. Hope I have been some help
Posted on May 28, 2008
Kp-65wv600 looks like I'm watching a 3D tv but not tv isnt 3D It has a blue, green and red out line behind the person could it be the lamp light and if so what color
Hello sburdano,
Welcome, and thank you for using FixYa!
To answer your question: The colors are all working, they are just out of alignment.
Judging by what you have said hear, I would assume that the television have been moved, rather roughly, or bumped into rather abruptly. The color wheel will need to be re-aligned to the lamp and lens. You need to find out what your local TV Repair shop would charge for re-tuning.
Have a great day!
Dec 01, 2011 | Sony KP-65WV700 65" Rear Projection HDTV
We own a Sony Sony kp-53xbr4ct and recently the image on the screen began to look like a 3d picture with red and green colors. Some research on our end points to a convergence problem. My question is...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 12, 2011 | Sony KP-53XBR4CT 53 in. Rear Projection...
I have a sony rear projection tv that went on then off rite a way the red lite blinked 7 times i took the front panel off and adjusted the 6 color tuners and the tv stays on but there is a blue 3d look ...
7 blinks means High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mar 08, 2011 | Sony KP-51WS500 51" Rear Projection...
I have an RCA D40W20 HDtv with the same 3d looking convergence problem. Is mine as easy to do as the Sony KP-51HW40 solution from 2 mnths ago?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D, wavy, or has a shadow or shadows
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
69189a5.pngSOLUTION
Jan 26, 2011 | Sony KP-51HW40 51" Rear Projection...
I have a large sony hd read projection / a few days ago - i started getting faint green lines that are arched - higher in the center - symmetrical, an about 1.5 inches apart - a few times , the tv has...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 09, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
My TV (module # KP-57WS500) is in a weird double vision view as if it is in 3D. with blue,red, colors. top and bottom of the screen also curve into the center of the tv. worked perfectly fine night...
  • Screen looks 3D
69189a5.pngSOLUTION
Nov 24, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony tv kp-46s25
how many times does the light flash cause it might be an error code from the shut down circuit
Apr 12, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Blinking 4 times - Sony KP 51HW40
Hello scramble5,
This might be a convergence amplifier problem or a problem in the convergence coils. I would suggest that you have a qualified TV technician check this TV out. This problem is usually due to the convergence amplifiers malfunctioning, to replace then the two modules and their biasing resistors must be replaced.
I hope this helps
Thank you,
Shuttle83
Jan 27, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-61HS30 TV Logo
204 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
