Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
SD1000 _ Wont turn on and I'm on vacation!! WHY!!!
Hi There,
My 3 month old SD1000 Poweshot Elph won't turn on and I am on vacation! I have used it before and the battery is working and charged. I tried cleaning the latch where the batter touches, but that doesnt seem to tbe the problem. Need help please!!!!
  • 4 more comments
  • jennyep Mar 17, 2008
    I have tried charging both of my batteries and the camera is still not turning on. Can someone help so I do not have to buy a new camera?
  • Katehwaliu Apr 07, 2008
    My Canon SD1000 wont turn on even though I just put in the new battery. What should I do? Please help.
    Kate
  • Anonymous Apr 26, 2008
    I have the same problem....camera won't turn on and | foundout on the first day of a month long vacation!
  • TNDave May 11, 2008
    stopped powering on...bought a new battery and it worked for about 4 weeks then started doing the same thing....any ideas?
  • wendilicious Sep 16, 2008
    my camara wont turn on at all either and its about 2 months old or even less...im not sure but i want to know if by down loading my pictures from the camara memory card to the computer gave it a virus..is it possible ?!?!?
  • Anonymous Feb 23, 2009
    I have the same problem with this camera. Im in Rio at Carnaval and wont be able to take pictures at the parade tonight. Thanks for leaving some ideas on this site but it looks like this camera was a BAD buy.
Its work after putting a piece of paper in little pin on the latch
Thanks
Posted on Dec 01, 2008
You may want to try if the little black latch contact next to the battery and the memory card is not working properly. Open the battery latch, press down on the little black contact using a pen and try to turn on the camera. If so, the latch doesn't engage that contact any more in regular use. If not, no luck. I had this problem and fixed it by putting a small thick piece of tape on the little pin on the latch that is supposed to press this contact.
Posted on Sep 24, 2008
    Scholar:
  • 46 Answers
Withe the PowerShot Digital Elph cameras there is unfortunately very little that you can do for a power problem besides determining that either the rechargeable Lithium ion battery or the battery charger itself is not the problem.
Of course a good battery will work fine in another similar camera. Usually the charger works OK if the lighting sequence on the charger goes from Red to Green on a low battery within a 2 hour period of time (it should also alternate between red and green when the battery is approximately 90% charged).
If the battery and the charger are in good working order then the camera likely has experienced an electrical communications error within the power circuitry which, more often than not, is due to some sort of impact damage. Often users don't realize that their cameras have experienced impact damage but these cameras are unfortunately very fragile. A fall of as little as two feet can do sufficient damage to require service.
Given the scant amount of surface area that the contact plates actually have with the camera body, cleaning these areas will rarely effect a solution and resets cannot be performed on cameras with no power, so the result, unfortunately, is that the cameras will typically have to be serviced.
Hope this helps.
Sincerely,
HeavyDLB
Posted on May 31, 2008
Battery wont charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 04, 2012 | Canon PowerShot SD1000 Digital Camera
Canon elph won't turn on
check the battery then batt. connectors
May 21, 2012 | Canon PowerShot ELPH 300 HS 12.1 MP...
CANON SD1000 can't TURN vertical downloaded video into horizontal
If you have windows movie maker (its part of the default installation of windows XP) you can use the rotate filter in the video effects tools.
Import your video into movie maker and select "Video Effects" under tools.  Scroll through the various effects until you find the "rotate 90".  Apply the effect and save the video.
I hope this helps!
Nov 25, 2008 | Canon PowerShot SD1000 Digital Camera
Can't download large movie files to iphoto : (
i found the answer to my own question above and thought i'd share.
rather than iphoto, you can use "image capture," which is software that comes standard with the mac.
-Turn on your camera, and connect it to your computer with the cable that came with it.
-Close iPhoto if it opens automatically. Open Image Capture (Applications folder).
-Click Download Some to choose specific items to transfer, or click Download All to transfer all items.
If you click Download Some, choose the items to transfer, and click Download.
By default, Image Capture transfers still images to your Pictures folder, video files to your Movies folder, and music files to your Music folder. To choose another folder, choose Other from the Download To pop-up menu, then click Download Some or Download All.
Jul 20, 2008 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
162 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
