Problem setting up a dongle to my PC
I'm having a problem setting up a dongle to my dell dimension 3000 with windows XP to enable my wireless router to work. I insert the dongle into the usb point and pc recognises that there is new hardware, I then insert the disc as suggested by the set up wizard and it lloks like the installation is starting. At no point does th dongle light up and the process fails with the error:
The system cannot find the file specified.
  • Sergio Scalfaro
    Sergio Scalfaro May 11, 2010
    model of your dongle?
    Sergio
  • Did you rate Tony's answer? This was thed best answer for you and you didn't rate when he worked hard to help you
  • 38 Answers
NEVER install the dongle before the CD.
What has happend is windows has automatically installed your dongle with the wrong driver.
Try this.
Keep your dongle plugged in.
Goto start > control panel
Click system
Along the tab at the top select hardware, now click device manager.
Find your dongle, it should be under 'network adapters' (if you are not sure if it is the right one, unplug it at this point. If it dissapears from device manager - that is the one)
Now, click on it in device manager and press delete. Click OK to deleteing the driver.
Now, follow these steps carefully:
Unplug the dongle.
Restart the computer.
Start installation from CD
Only plug in the dongle when it tells you to, or the installation is complete.
Hope this helps
Tony
Posted on Mar 04, 2008
Do the dell xp monitor 8110 have wireless
It won't have a wireless connection built into the computer. You'll have to purchase a separate dongle for a wireless connection. You can pick up a wireless adapter for around $30 USD.
Dec 25, 2011 | Dell Dimension 4600 PC Desktop
Dell dimesion 5150 wont install wireless dongle
Hi, there is a proper solution for you.
Just follow these instructions gradually...
1. Install its software from the dell web.
2. Before choosing the driver choose operating system as XP.
(You can use the following link; http://www.dell.com/support/home/us/en/19/product-support/product/dimension-5150x/drivers)
3. When ask for the device or dongle attach then not before starting the installation.
Hope it will work perfectly, feel free if you have any question.
Good Luck
Dec 23, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Can i put a Internet dongle on my home PC and connect to the Internet i don't have a bt line.
If you have a wireless router then yes you can use a wifi dongle. The only reason BT users can is that BT comes with a free wireless router (bt homehub) Max
Feb 11, 2011 | Dell Dimension 3100 PC Desktop
I'm trying to configure add my dell dimension 3000 to a netgear wireless router via a linksys devise. This would be adding a 2nd computer to the wireless router. I know the password. I'm getting a error...
Do You have an association button on Your router? If so, the firstly press the button and then try to connect. If not, You must enter IP address of Your computer, like 192.168.0.5 Subnet mask, like 255.255.255.0 IP address of router, like 192.168.0.1 Then, most important - default gateway. If You have another computer connected at the same router, run cmd, then ipconfig in the black MS DOS window that appears after cdm command. Here You can see all parameters of Your TCP/IP configuration. Take a note of the default gateway and put it to TCP/IP settings of Your Linksys device. If it not help, drop me a message.
Sep 10, 2009 | Dell Dimension 3000 PC Desktop
Wireless router with dimension 3000
It seems that you have Dell Desktop computer, unless you requested a wireless card to be put into the computer, it would not come with one. Just like stang_1 mentioned, you should check your network adapters to see if your wireless card is listed. Also since it is a desktop, you can check the back of it to see if you have an Antenna sticking out of it. That would indicate that you have a wireless card on the PCI slot. And if that is the case and you do not see it listed in the network connections, check the Device Manager and make sure that the drivers are installed properly.
Apr 14, 2009 | Dell Dimension 3000 PC Desktop
Dell dimension 3000 won't see wireless network
Hi, I've jst been looking on the web at the Mimo routers, you may find this article interesting, it may help even though its a couple of years old?
http://www.behardware.com/articles/614-2/wi-fi-mimo.html
Pay attention to part about 802.11n compatibility?
Perhaps try changing the IEEE standard on the router to 802.11g in the set up pages, as it may be set at 802.11n, which your older wireless card will not see.
As to the acquiring ip address message, try using a static ip address, here's a good guide:-
http://portforward.com/networking/static-xp.htm
Maybe this will help?
Jan 27, 2009 | Dell Dimension 3000 PC Desktop
No ethernet port on older Dell desktop
Yes, all you need is a PCI ethernet card. You can pick them up rather cheap. Here is one. You basically plug it into an available PCI port on the inside of your computer. If XP doesn't automatically install it, just insert the included CD with the drivers on it and XP will do the rest. And remember to please give this answer a good rating of fixya. Thanks.
Dec 26, 2008 | Dell Dimension 2400 PC Desktop
Dell dimension 3100
I´d suggest getting a usb wireless adapter....you should certainly have no problem with the specifications of your pc ....usb wireless adapter is cheapest and easiest option
Nov 26, 2008 | Dell Dimension 3100 PC Desktop
Sound windows xp dimension 3000
hi if your motherboard have you install sound properly....Or not your sound driver you Go to driver Zone.com then download it
Jun 06, 2008 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
487 people viewed this question
Alun Cox
David Payne
David Payne
