Question about Dell Inspiron B130 Notebook
Toshiba M15-S405 Battery Won't Charge
The laptop will work fine off of the AC Adapter. The charge light is amber (for charging) but never changes state to indicate charged. I replaced the battery. It came from Toshiba at 50% charge. It did not charge and the percent of charge is now 36%. The battery and the AC adapter appear to be working but the battery does not charge.
Does anyone know if the charge circuits are part of the motherboard or a separate, replaceable daughter board.
Any assistance would be greatly appreciated.
Thanks,
Randy
  • rwilliams146 Mar 04, 2008
    I did not believe what you stated at first but, I measured the voltage out and it was 15VDC. I then read the voltage on the AC scale and it was over 20VAC.
    Now to find a power pack . . .
    Thanks,
    Randy
  • 106 Answers
Hello,by anoteher charger,you`r capacitor on charger is poor.best solution for you is to by a new charger,that is 100
Posted on Mar 03, 2008
I started charging my toshiba satellite M15-S405 laptop with a universal charger, IGO ac power adapter,with a #702 head/tip, that i bought from wal-mart, and its been having a yellow blinking lite in front...
Disconnect the adaptor and remove the battery from your notebook. Then connect the power adaptor and see if it boots up. If it powers up OK now you may have a bad battery. If the notebook still will not power up, the adaptor may not be compatible or there may be a different hardware problem.
Sep 03, 2013 | Toshiba Satellite A75-S226 Notebook
Dell c640 battery not charging
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Mar 02, 2013 | Dell Latitude C640 Notebook
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
Samsung N145 Plus battery charge failure
Sep 03, 2012 | Samsung Computers & Internet
The toshiba laptop a505 S6980 will not charge the battery when the AC is plugged in and dies immediately if unplugged . Meters shows 0% available (plugged in), charging. But it is not really charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Apr 20, 2011 | Toshiba Satellite L500-ST2521 Laptop AC...
Unit will not power on// has a solid amber light// turns green for about 3 seconds then back to amber
You may have a bad DC connector:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 17, 2010 | IBM ThinkPad T20 2647 Notebook
?how do I charge the battery
You use one of two methods
Method 1
1. Install the battery in its compartment.
2. Plug the AC adapter
The battery will start charging, and the status light for the battery will appear amber. The light will remain amber as long as the battery is not fully charged. When the cahrge is completed, the light will turn green.
Of course, if your are using your computer while battery is being charged, it will take three to four times longer to complete the charge.
Method 2
Toshiba sells battery chargers which you can use to charge a battery outside of the computer.
Hope it helps.
Aug 26, 2009 | Toshiba Tablets & eReaders
Toshiba 1410-S173 battery charging light blinks amber
did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
Mar 03, 2009 | Toshiba Satellite 1415-S173 Notebook
Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Mar 14, 2008 | HP Pavilion dv6000z Notebook
Toshiba power problem
hi there!
im sorry but if the ac adapter flickers when you plug it in to the computer, then you have to replace the system board.
Regards,
Karlox
Jan 22, 2008 | Toshiba Satellite Pro M15-S405 Notebook
Dell Inspiron B130 Notebook Logo
155 people viewed this question
Alun Cox
