Question about GE 46GW947 46" Rear Projection Television
Philips 54 rear projrction tv
My problem is that i need a front screen for this tv the frame and the first sceen was blowed off while it was being moved so need the frame and first screen i think it is called a lenticlar screen
  • 133 Answers
You can go to enter your model # and see what is still available . They can be expensive and make sure you check out the shipping cost . Good luck
Posted on Mar 04, 2008
My samsung 47 in projrction tv has blue gosting or a blue double
Thats usually related to the convergence Ics and the 3.9 ohm resistors needing replacement.
Jan 23, 2010 | Samsung HC-P4752W 47" Rear Projection...
Can only get "4:3" and "compressed 16:9" screen format. Want full "16:9" not compressed. How?
HDTV ready means that it will process HDTV signal to be viewed on you set. The size of your screen is still in a 4:3 ratio. Unless you have a true 16:9 size sceen you cannot get the full 16:9 picture. The actual physical size of the sceen is what makes TV's true HD or not. In other words, the screen has to be twice as wide as it is tall or 16:9. Your screen is almost square or 4:3. It can only show a compressed version of the 16:9. Thanks for using fixya.
Dec 13, 2009 | Philips 60PP9202 60" Rear Projection...
I have a philips HD rear projection TV 60 in. inside there are six adjustment knobs. Three are color the other three are for brightness contrast and hue. Which is which Left to right
If yours is a rear projection TV the adjustment knobs on the focus block inside are screen (red, green, blue) and focus (red, green, blue). The ones you are referring to as color are the screen controls and they adjust the intensity of the color from each tube. The other set adjust the focus of each color. They are also not intended to be adjusted by the user. Unless major components have been changed these controls should not need adjustment. That is why they are inside the TV.
Dec 05, 2009 | Philips 60PP9352 60" Rear Projection...
Have 54" magnavox. works great. took screen apart to clean. can't get the correct order of assembly so the picture is right, need screen assembly info. could i have hurt the plastic ridges in cleaning?...
The outer screen that has the vertical ribs will face the front of the set as you are looking at it.. The other will have a circular pattern as you can see, that will face the rear of the set, so the smooth side will be toward the back of the front screen.
If you have damaged the screens then try and MCM
Sep 23, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How do I replace the Vertical Output IC
Replace the Small Signal Board Part #313912725871
This is a common problem withis TV.
Jul 30, 2009 | Philips 50P8341 50" Rear Projection...
Magnavox 54" Projection screen TV
Replace your STKs 392-110s with 180s if 020s go with 040s
Oct 27, 2008 | Philips Magnavox 51MP392H Rear Projection...
47"Epson Rear Projrction TV
turn power off.
let rest for 30 mins.
take off right front panel.
open door to lamp.
unscrew lamp.
pull out and replace.
might want to unplug set also while working on it.
Aug 01, 2008 | Epson Livingstation LS57P2 57" Rear...
Need replacement screen for Mits. WS-48511
The other site i am associated with has used screens for mitsubishi you just have to post the measurements of your screen top to bottom and side to side dont include the frame size as we allow 1/4 inch for fitting in the frame just need the size of the screen to the frame edge.
Mar 31, 2008 | Mitsubishi WS48511 48" Rear Projection...
Need to disassemble Mitsubishi VS-6041 60 in Rear Projection
Wow, You are asking for a complete disasemmbly. If this is necessary, you have to remove any screws you can find that are connected to the front panel. Usually they are in the top of the set ( you'll find them after removing the mirror panel and mirror ). I wouldn't remove any tubes as the tube convergence would have to be all reset and that would require a cross hair generator. I do hope this has helped in some way, but all I can do is send you my best wishes as I certainaly don't suggest disassembly if there is any other way. Good luck
NC Electronic
Mills, Wyoming
Nov 24, 2007 | Mitsubishi VS-6041 60" Rear Projection...
GE 46GW947 46" Rear Projection Television Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
