Question about Kenwood KDC-135 CD Player
Adding new speakers to the deck
I'm adding a pair of tweeters to my car... and i dont want to go through the door.. so ive been advised to hook them up through the deck which is a kenwood kdc-135... how do i do this? do i just take the tweeter wires and direct them into the right speaker and left speaker spots in the deck? please help!
  • 33 Answers
You need to know if these are Pizo tweeters or dome tweeters. If Pizo just hool them up to the white and gray wires off the kenwood. if not, then you should go to your local stereo shop and by bass blockers (small capacitors will do). this is only to "erase" the ohm load. once you have those inline of the POSITIVE wire you can hook the up to the gray and white wires. Good luck hit me back
Posted on Apr 04, 2008
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
I have alpine sps600c & am installing them in a 2001 Nissan frontier w/ 6 disc 6 speaker (2 ea in each ront door, 2 in back (crew cab). Do I wire my tweeters to existing tweeter output, or...
Did you change out the factory deck? If not, wire the tweets to the existing wiring. If you already have tweets they have been crossedover already. However, if you replaced the deck, you may need to run new wire to the doors and use the crossover that came with your component set. Hope this helps
Sep 05, 2011 | Alpine SPS-600C Car Component System
What size are the tweeters in a 2000 gmc sierra extended cab truck? In the door, there are 2 sets of speakers. The 6 3/4" and another smaller pair. What is the size of the smaller set? I have a 2000...
Hello.. the tweeters in the doors are 1 inch tweeters, but they have a large housing. Every set that I have come across are usually hanging because the 2 plastic nipples that go through the panel break off. They have a self-threading bolt on the back and they all eventually come off. You can rotate the tweeter slightly and run a panhead screw with a stinger tip to keep them up. If you are adding a pair of tweeters, just leave those in the door panel and just remove the metal grille that covers the speakers and add them next to the factory ones. You can just wire them in with the factory wiring. Just be sure to wire it on the door panel clip side so you can remove the door panel without having to cut the wires every time. You will have to remove the panel to gain access to removing the metal grille on the panel. Hope this helps! Good luck with your venture!
20 year car audio/video installer
Bay manager
Mar 17, 2011 | Car Audio & Video
My jvc mx-d622t shelf stereo simply stopped working. No power at all , Course I do have 6 speakers hooked up to it, just added the third pair the day before it stopped working.
Are these speakers compatible or are you just adding speakers because you have them hanging around?
If you have effectively less than 6 ohms of impedance on any channel you may run into problems and the unit may either die or protect itself by refusing to stay ON.
It's fairly obvious that if you do X and undesired Y happens you might want to UNdo X and rethink it.
May 29, 2010 | JVC UX-GP5 Micro Stereo Audio System Shelf...
Hello again. Sorry to say my knowledge is lil... I want to replace stock deck. Here is the stuff i want to put in it. Could you take a look and give an opinion if maybe i cant get away without putting a...
ok as for the deck just get the wiring harness for your car so you dont have to cut the old one out and that would eliminate the need for a wireing diagram with that done you should be able to hook all speakers you want to the stock spot so for a tweeter just hook it up with the door speaker there arnt any extra cords....you will only need a amp for a subwoofer unless you choose to put your mids and highs on one and if you didnt want to change your deck hook up the tweeters would be the same way hope this helped
Mar 30, 2010 | Car Audio & Video
Cannot figure my rear speaker wiring in a 94 chrysler lhs. there are 4 wires for each 6/9
You have 4 wires because 2 are from stereo and the other 2 go to another speaker like a tweeter. You can either hook up the ones from the deck and leave the other 2 at the lose of tweeters. or hook the + together, and hook the - together
Mar 23, 2010 | Car Audio & Video
2002 Grand am gt monsoon, hook up rear aftermarket speakers
You have to test them, either should work fine (as in use either pair) if that doesn't work connect one pair at a time and listen for the difference, one pair might be for factory midrange and other for tweeter.. there are two different wiring configurations...
Jan 28, 2009 | 2002 Pontiac Grand Am
I dont know how to install tweeters
only if they have a crossover attached if you dont they will blow up!
Jan 21, 2009 | Boss TW-25 Car Tweeter
Adding speakers to truck
use the right front lead as it is a front spearer fade featuer on radio will then work properly
rate and vote my solution ty
Dec 11, 2008 | Car Audio & Video
Kenwood KDC-135 CD Player Logo
71 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
