Monitor won't turn on.
Power went out in my house for 2 section. Tunred computer on. Now monitor won't turn on. Suggestions? Thank you for your time.
  • Anonymous Feb 27, 2009
    help,flatron wont turn on,but does work ocassionaly,we kept having power interuptions,out of he whole house its the only item thats playing up,it was not lightning that caused the power interuptions,any ideas?thank you
  • 151 Answers
Chheck poer cable of monitor.if it is ok then check on off switch of monitor .and it is ok then check fuse inside monitor in power section.if it is ok then check horizantal output transistor.
Posted on Mar 04, 2008
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your monitors. Power on both CPU and monitor. After that, you have to check if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
I have a Westinghouse L1928NV computer monitor that appears to be no longer working. It was fine yesterday but last night the power went out and now it is completely unresponsive. Suggestions? Thanks
charla186, I think that you will need to have it evaluated by a TECH type of person. If unit will not turn on it could have a 'switch-mode-power-supply" failure and / or "backlight" inverter supply failure. You didn't state the AGE and or approximate "ON" hours this unit has. I don't quite know what you mean with "the power went out"?? Power to the whole house or office? or did you mean just the LCD monitor? Here are some options you might try. Warranty??? or Check with Westinghouse about a CASH + old monitor swapout for a fully refurbished same model. Have a local TECH at a TV/ monitor repair shop evaluate it's condition. I will also suggest you visit YOUTUBE and view some short video clips of LCD monitor disassembly just so you know what is inside a typical LCD and then know what the top 2 causes of monitor failure are. In any case get back to me and let me know what you think you will be your plan of action. I'm louie12fix on fixya or lmistyrel@aol.com Bye for now
Oct 04, 2009 | Westinghouse L1928NV Monitor
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
COMPUTER WON,T YURN ON
first of all,is your power cable properly connected to your system unit.if it is not,connect it properly and turn the system unit on again
secondly,make sure your signal cable from the monitor to the system unit is properly connected
after following these instructions,reboot your computer again.
thank you for consulting fixya with your problems
Feb 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Horizontal Tearing when monitor comes out of sleep moe
Plz check memory ic of monitor in command section.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 11, 2008 | CTX P772 17" LCD Monitor
174v monitor not weorking
check power section.check pf capacitors in this section for ok or replace them.
Feb 24, 2008 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Monitor
Check relay in power section for fault.To degaus the monitor.
Jan 10, 2008 | Samsung 793S 17" CRT Monitor
My monitor is in sleep mode and I cannot get it out if it.
Sleep Sleep is a mode that the computer enters after being inactive for a set amount of time. Commonly, this mode will turn off a device or set it into a stand-by
Engergy star No data is lost when computer components enter a low-power mode, ... keyboard would get the computer out of this mode. Also see: Power Definitions, Sleep
This should wake your computer, Good Luck/Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion F1703 17" LCD Monitor
Gateway monitors not powering on
Do you get an Amber light on either monitor?
Jun 21, 2007 | Gateway FPD1950
Computers & Internet Logo
1,395 people viewed this question
Alun Cox
David Payne
David Payne
