Question about RCA Scenium HD65W20 65" Rear Projection Television
Fuse locations for RCA Scenium HD65W20
I am trying to locate where the fuses are on the HD65W20. Can anyone help? My TV was working just fine, then there was a power alarm on the UPS it was connected too and everything powered off. Restored power to everything, but the TV won't power up. Plugged it in directly into an outlet, and still nothing. Can you help me locate where the fuses are ?
    Genius:
  • 1,030 Answers
There are 2 fusable devices in this chasis dt307 they are f14200 and f14100 fl200 6 amp 125 v is located Power supply pcb. left rear chasis. f14100 3 amp 125v dm1 power supply pcb left rear. Does the unit have no flashing light... good luck on your troubleshooting and if you need any help contact me via email at the my shop at willie@fordtv.com
Posted on Mar 03, 2008
Hit by litning
my friend it is the tv tunner that needs to be replace you will have to take your set to a repair shop for repairs.tv needs qualified tech to repair them.you might cause injury to your self.although you want to save money it is best to have a tech deal with your tv,than doing more damage to your tv and to yourself.it will cost you less on the longer run.good luck
Jun 19, 2007 | RCA Scenium HD65W20 65" Rear Projection...
Tv not coming on just red light flashing on and
thomson scenium jw 611s not coming on just red light flashing on and off at front of tv
Jul 13, 2010 | RCA Scenium HD65W20 65" Rear Projection...
Can I buy the green vender board with part # 1558635C for my HD65W20 TV
That part number does not go anywhere,. Please post the name of the board you are looking for.
Dec 28, 2009 | RCA Scenium HD65W20 65" Rear Projection...
The humming noise on my rca scenium starts just a
If this is a DLP set, which I suspect it is....you need a new color wheel. Common problem for these sets. If you don't have an extended service plan, about a 300--400 fix, in home.
Oct 09, 2009 | RCA Scenium HD65W20 65" Rear Projection...
Double image.
First when replacing the small sig. board a full convergence must be done,the other trouble is most likely the front panel buttons,this is a repair a service center must do,sorry best i can do from here
Mar 10, 2008 | RCA Scenium HD65W20 65" Rear Projection...
Won't turn on - except for one cooling fan
thee is a fuse near the power plug-in it's a 6amp 125 v ....make sure you bring the fuse with you..will solve the off problem
Dec 07, 2007 | RCA Scenium HD65W20 65" Rear Projection...
I have an rca scenium
turn off autoformat in customer setup
Feb 25, 2007 | RCA Scenium HD65W20 65" Rear Projection...
Pop and burning smell now no picture
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Jan 03, 2006 | RCA Scenium HD65W20 65" Rear Projection...
RCA Scenium HD65W20 65" Rear Projection Television Logo
311 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
