Chopsaw Hi got a problem with a Makita ls 1013 Sliding chop saw when you turn the machine on the saw blade comes loose and wobbles even when every thing has been tightened and checked any suggestions
  • Rickyegrant Mar 05, 2008
    cheers will check it out
  • Gary Davd
    Gary Davd May 11, 2010
    does it wash clothes??....... you have this posted under washers??
    Problem Solver:
  • 14 Answers
Hi hope to help you!
firstly see if the blade is going the correct way if so
you should replace the spindle shaft and also fit a now bolt only use makita parts though!!
the problem is the thread in the spindle and bolt are worn.
Hope that helps. Sean.
Posted on Mar 04, 2008
The guard on my makita chop saw keeps dropping down under the blade and will not return to the correct position unless you pull it up with you hand
Sounds like you have a broken spring, which you may not be able to see.
Type "Makita chop saw" into the search engine of your computer, and a list of dealers should come up for you to call and ask your question of.
God bless your efforts.
Dec 11, 2017 | Makita Saws
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
How do I remove a flywheel on a Makita chopsaw
Not sure what you mean - are you talking about the flywheel on the gas engine of a 14" saw?
There are no flywheels on a chop saw.
Sep 24, 2014 | Drills
Gaurd assembly for makita LS 1013 chop saw.
Try this:
How do I have a product or technical support question answered? Please contact the Makita U.S.A., Inc. National Call Center between the hours of 8 a.m. and 6 p.m. EST at (800)462-5482.
How can I order parts for my Makita products? Please contact the Makita U.S.A., Inc. National Call Center between the hours of 8 a.m. and 6 p.m. EST at (800)462-5482. You can also search for a local dealer in your area by choosing the "Shop" tab at the top of the Makita web page:
and click on "Where to Buy." You can input your zip code to find a distributor in your area or click on the links to our online dealer
Jan 14, 2012 | Saws
I want to replace the blade on my chop saw mdl.#LS 1030
the bolt is left hand thread, hold the spindle lock button and remove the blade. unplug tool first
Jan 11, 2011 | Makita Saws
I have a Makita LS 1013 compound miter saw. The locking knob that locks the saw from sliding back and forth no longer works. I downloaded the owners manual and parts list but I can't seem to correctly...
check position 79 the spring that pushes against the table and also the end of the locking knob to make sure not rounded over/worn not applying pressure to the locking spring.
Dec 19, 2010 | Makita 10" Miter Saw LS1030N
I casnt remove the centre nut from my c8fse chop saw
Hi, when I do this I insert a large screw driver into the blade saw to stop the blade turning, as you will need to turn the nut clockwise.
Aug 01, 2010 | Hitachi C8Fse Sliding Compound Mitre Saw...
My dw718 chopsaw is making a funny noise, the blade seems to be stuck and smoke coming from the motor. whats wrong and can it be fixed?
Sounds like the brushes have gone bad. You should be able to get new ones from
Feb 01, 2010 | Dewalt Chop Saw D28700
Blade acts unusual
Hi, Blade wobble at high speed can be very dangerous! The saw at the right ( wrong) wobble can destroy itself.There are a few things that can cause it, And you have to check them as best you can before you power it back up. Check the blade, you can lay two blades together and check for gaps anywhere. Check that the hub and spindle are flat where the blade goes. (No lock washers) Also check the spindle for side to side movement, there shouldn't be any. Turn the spindle by hand and see if you feel any grit or sandy type feeling, you shouldn't. Lastly, if you don't find anything, try a new blade of a different type, and if it wobbles again, check and see if you have any warranty left and even if you don't you should contact Makita about it.
About the best I can do from long distance. Let me know what you find, Please.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 31, 2009 | Makita 10" Compound Miter Saw LS1040
LS 1013 chopsaw
There should be two knobs on the saw where you adjust the miter of the saw. One of these knobs if turned clockwise tightens the swivel. I have the same saw except it is a 13 amp.
Oct 22, 2008 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Washing Machines Logo
236 people viewed this question
Top Washing Machines Experts
