Question about Kenmore 24032\24036 Top Load Washer
Broken Washer The washer will drain, however it won't spin. It makes a grinding noise when the switch is set on spin. The washer is only 4 years old. Please help!!!! Thank you
  • 6 more comments
  • Cant Fix Mar 04, 2008
    Thank you for responding. It appears the washer will not agitate either. I turned the washer on the side and viewed the motor while my wife attempted to engage the the spin cycle. The small post at the end of the motor will only move slightly while there is a lound grinding or clicking noise apparently coming from the motor.
    Thank you so much. The washer is a Kenmore Elite, model #110. 22932100, SN# CL 4137690.
    Got it. Thanks again. I'll let you know if I am able to fix it
  • jnicholegc Mar 04, 2008
    how to change washer coupling..
  • Anonymous Mar 09, 2008
    drive coupler broken
  • valkaz Jul 09, 2008
    I have the same issue with a similar machine:
    Kenmore 80 Series, Type 111
    Mod: 110 24862300
    SN: CP 5145884
    Since I am a driven single mom, I want to save some money and fix this myself. Is it difficult? Do I need the same part number? Can you send the repair instructions to me also?
    email: valkaz@hotmail.com
    Thanks!
  • Kody Lawrence
    Kody Lawrence Nov 06, 2014
    I have had a similar issue with my washer. I was a newer dryer too so I didn't have the money to just go buy a new one. I had a repair service come out and take care of it for me. http://www.a1applianceky.com/services
  • 770 Answers
Sounds like you have a broken drive coupling....will the unit agitate ok??
Posted on Mar 04, 2008
  • 1 more comment
  • Gary Davd
    Gary Davd Mar 04, 2008
    your drive coupling is broken you need to get Whirlpool part number 285753 you can change this yourself.. post you email plz i will send you the procudure
  • Gary Davd
    what is your email i will send you a step by step to fix it
  • Gary Davd
    check your email
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer is loud, and won't spin or agitate
check the motor bushes,and also check for bearings in drum you can check this by lifting the inner drum up and down if you feel a knocking noise then this will be the bearings have worn.
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
WHDRR418G1WW WASHER WON'T AGITATE OR SPIN, NOT MAKING NOISES. FILLS AND DRAINS FINE.
sounds like you have a broken lid switch on the washer, maybe someone slammed the door or placed or stood on top of the washer, a broken lid switch won't allow washer to go into spin mode is a safety device so if is on spin cycle an someone sticks their hand it the machine stops an not breaks your hand.
broken lid swtich
good luck leave some feedback thanks!
May 28, 2009 | GE Washing Machines
Grinding noise while agitating.
possible foreign substance under agitator
Feb 26, 2009 | Admiral AAV7000A
Grinding noise,unit stopped, burning smell?
broken or slipping drive belt, motor to spin pulley defective drive clutch, spin brake fails to release to transmission is frozzen
Oct 07, 2008 | Admiral AW22 Top Load Washer
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Kenmore 90 Series, washer Model 24924200
probably a sticky or broken bearing clutch, call a repairman. Probably be under 100k dollars to repair.
Jan 29, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
366 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
