Question about LG RU-44SZ63D Television
TV shows high temperature on screen
I have had this problem twice, that the high temp shows on the screen, but what happens is that somehow the programing of the temperature setting gets out of its parameters. The repairman used the remote to reset the settings. How can I get into the program to reset?
  • 2,336 Answers
How old is the TV?
Have you replace the lamp yet?
If you want to get into the service mode to make those adjustments, you can only do it if you have the service manual.
I would suggest to check if the fan is operating properly, or the filter is clean if applicable.
There might also be a temperature sensor that is not working properly or the lamp is giving up on you.
Let me know if you need more assistance.
Posted on Mar 05, 2008
  • 796 Answers
Hello do you have the manual for this tv set???
Why does my Tp Link M5350 3G wifi turn on and off?
When ”high temperature” shows on the OLED screen, the device is too hot, so place it in a cool, ventilated location. When the temperature is high enough, the device will stop charging/functioning in order to avoid damage.
This device responds to overheating whether or not it is charging.
When the device is charging:
• The device is powered on. When the temperature is higher than 113°F/45°C but lower than 140°F/60°C, it will not show “high temperature” but it will stop charging.
• The device is powered on. When the temperature is higher than 140°F/60°C, it will power off & stop charging. Also the OLED screen will show ”high temperature” at that time.
• The device is powered off. When the temperature is higher than 113°F/45°C, it will stop charging & the OLED screen will show ”high temperature."
When the device isn’t charging:
• Only when the temperature is higher than 140°F/60°C, will the OLED screen show “high temperature” & this device will power off.
May 04, 2015 | Computers & Internet
Sony KDL-V32XBR1 that is giving me a High Temperature Warning
Check the tv is not against a wall and the air vents are not clogged with fluff. A flat screen tv expensive to repair.
Dec 24, 2014 | Sony KDL Televison & Video
KDS-R50XBR1 TV red light blinks "2" "two" times
For the KDSR50XBR1, 2 blinks, pause, 2 blinks, etc. means "Temp (temperature) error" and the probable cause location listed is as follows:
- Set temperture is high.
- Temp sensor connector is not attached securely. (CN7020 on HB board, CN7180 on S2 board)
Read more: http://www.agoraquest.com/viewtopic.php?topic=34237&forum=34#ixzz2FYUZCl00
Dec 19, 2012 | Sony KDS-R50XBR1 50" HDTV
Oven is showing f2 what is happening
Hi Nancy:
Error Code F2 indicates a loose or broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced.
Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Hope this helps; thank you for using Fixya. Keep in mind that your feedback is important, leave us some testimonial comment.
Nov 24, 2011 | Magic Chef Ovens
Machine in cold shed. Supply pipes no longer frozen, but machine still displays F37 error and beeps and no water getting in. Have tried presssing temp button twice but no good.
F37 is because of operating the unit below specified temperatures.
Pressing the temperature button twice shows a snowflake and sets a defrost function.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 09, 2010 | Washing Machines
Hotpoint WT540 when set to temp 30 wash programme H it has shrunk woolen jumpers twice now. Is their a temperature sensor that could of failed or is there another reason why this should happen. Is there a...
There is a temperature sensor, it is called a Thermistor, and they have been known to fail,
It is usually located at the end of the heater fixing plate.
But it could be also a board problem.
You can get a thermometer to test the temp , there is an infrared one that you point at the liquid or article you need to check the temp of,, and it shows the temp on an lcd screen, but they are not cheap.
At 30 however, the water should be no more thal luke warm, if it feels hot, then the temp is not being controlled
Mar 08, 2010 | Hotpoint Washing Machines
Lock light flashing after cleaning. Will not
OK, what has happen here is, the actual temp sensor has failed during the cleaning process, this has cause a temp that reached a dramatic high range(above 915F-930F). At these temps, there will be major damage that will weld the contacts on the door lock switch mechanism and control board.
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches for faults as well(welded contacts and burned wiring harness)
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Sep 23, 2009 | GE Ovens
Sony TV Keeps switching off
How old is your TV?
2 times blinks shows error of High Temperature of Lamp.
This model has 4 fans and all should be work properly.
Nov 08, 2008 | Sony Televison & Video
LG RU-44SZ63D Television Logo
164 people viewed this question
