Question about JVC GR-D290 Mini DV Digital Camcorder
The cassette holder wont come up aoutomatically
The cassette holder wont come up automatically and seem it stuck !
It says Unit is safeguard mode , and remove and reattach battery, I have done it many times, nothing is happening
What should I do ?
  • 1 more comment
  • indi25 Mar 04, 2008
    Thanks for your help
    The problem is no cassette inside, when i open the cover, normally cassette holder will come up and open automatically, but this this the cassette holder doesnt do anything . What should i do ? If i send it to repair centre it cost me £ 150 !
    Thanks for helping
    I have tried what you suggested but no luck (:
    Any idea ? still says safeguard mode and nothing happened
  • indi25 Mar 05, 2008
    Sorry still doesnt work, thanks for helping
    Will it help by opening the cassette holder ?
  • 91 Answers
What you have to do is ejecting the tape, and as soon as it starts to eject , close the door immediately, then safeguard mode should be gone, and you will be able to eject normally.
Posted on Mar 04, 2008
  • 1 more comment
  • Ronen
    Ronen Mar 04, 2008
    let me emphasize that after you try to eject press to close the door immediately even though the door didn't open.
  • Ronen
    Ronen Mar 05, 2008
    it doesn't matter if there is no cassette inside, you need to press eject, and when you here a sound that the door is trying to open, immediately press the door to close it.
  • Ronen
    Ronen Mar 13, 2008
    yes, open the cassette holder and close it immediately.
How do I solve the error message "E02 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY"?
clean the mode selector switch with contact cleaner spray, which lays beneath the cassette drive mechanism.
Apr 07, 2016 | Video Cameras
Error 04: unit in safeguard mode, eject and reinsert tape. However, after I opened the cassette holder cover, the cassette holder didn't automatically open, and I can't get the tape out. I tried taking...
hi
i am dammika
from sri lanka
i have a jvc handy cam
but it broken display ribbon
i want by it in sri lanka
how can i get
pls send me a sms 0094778280849
thanks u
Apr 26, 2011 | JVC Video Cameras
Says unit in safeguard mode wont let me operate
I have this problem with code 6 remove battery and reinstall. To fix I installed a JVC Cassette Head Cleaner and pressed play and seems to be working fine now.
May 30, 2010 | JVC Video Cameras
2 PROBLEMS WITH MY CAMCORDER
Some video cameras (Sony for example) have a tiny reset button that can be pushed with a tooth pick, and this does a factory reset and usually solves most lock up problems. The button is in an extremely small hole, usually in the side of the camera somewhere, and is marked reset. See if your JVC has one, and if so then try it.
Sep 22, 2008 | JVC GR-D250 Mini DV Digital Camcorder
01 error code - unit in safeguard mode
I solved the problem! Open the video cassette door. Look closely at the gear mechanism and see if there is any small debris in the gears. If not, using a magnifying glass and a paper clip(must stretch it out and use the tip) gently move each gear(gently). I had my unit ON. Once I moved the gear it became unstuck and ejected Mini DV cassette. I then re-inserted the cassette and it worked. The dreaded SAFEGAURD MODE message was gone and it is as good as new.
Be Blessed
dennis@privatemtglending.com
Aug 26, 2008 | JVC GR-D250 Mini DV Digital Camcorder
E04 unit in safeguard mode
I tried every method I could find from people posting on the web, but the method that worked for me is this.
1. Eject the tape and close the tape holder.
2. Turn the camera off and remove the battery.
3. Put the battery back in. Leave the camera off.
4. Open the tape holder.
5. Slide the tape in, but as you press the holder in to accept the tape, keep your finger pressing in on the holder, being careful not to slow the tape holder from moving downward.
6. Turn the camera on.
7. If it doesn't work the first time, press more firmly to help the tape holder accept the tape.
That's it. This method seems to work for me and lets me use the camera for a long while. If the camera is sitting unused for more than a few hours, I have to do it again. And each time I insert a tape, I make sure that I keep pressing as the tape holder lowers the tape.
Mar 27, 2008 | JVC Cybercam GR-DVL805 Mini DV Digital...
Safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Aug 07, 2007 | JVC GR-D240 Mini DV Digital Camcorder
Safeguard mode
My camera is on unit in safeguard mode and it says eject and reinstall tape! What do you suggest??
Jun 03, 2007 | JVC GR-D275 Mini DV Digital Camcorder
Unit in safeguard mode
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Mar 29, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC GR-D290 Mini DV Digital Camcorder Logo
611 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
