Question about Hotpoint RGB745 Gas Kitchen Range
Hotpoint gas oven
I have a hotpoint gas oven and it takes forever to heat up (approx 45 minutes to get to 400 degrees). It makes a sputtering sound as it heats. I does not maintain the desired temperature either. The self-cleaning never gets hot enough to really clean. Could the gas pipes be blocked? Is there a cheap fix for this or do I need a new one?
  • 57 Answers
This is an indication of low gas pressure to the oven. This condition may improve when other gas equipment is turned off and worsen when demands increase such as during cold periods where heating plants are running. Contact your local gas company to check pressures at the burners and adjust the incoming pressure to the oven accordingly.
If you found this helpful, please Vote!
Posted on Mar 03, 2008
On a Frigidaire Gallery oven, it takes forever for the oven to heat to the set temperature. 20-30 minutes. This seems like a very long time. Once it reaches the temperature the oven temperature is fine,...
Replace the door seals, they are the thin rubber strips around the front of the oven when the door is open. They are simple to change as they just clip on.
Jun 26, 2014 | Hotpoint RGB745 Gas Kitchen Range
Random intermittant crackling sound from Hotpoint electric oven
This could be insulation on the wiring or more importantly the connecting spot might be frying. In any event, disassemble it and check into it.
Feb 24, 2013 | Hotpoint Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven takes 30 minutes to heat up to 350 degrees
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 25, 2011 | Hotpoint RB757 Electric Kitchen Range
Hotpoint gas oven won't keep its temperature. I
The temperature sensor in the oven needs replacing. It is located in the back wall of the oven. About 3 inches long,metal and about the size of a thin pencil.
Nov 22, 2009 | Hotpoint RGB745 Gas Kitchen Range
Takes too long for oven to heat up
Hhi, Is this a gas oven? If the ignitor is going bad, it will not open the gas valve as soon as it should.
Please let me know so I can assist you further.
Vic
Jun 21, 2009 | Hotpoint RGB745 Gas Kitchen Range
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 | GE Ovens
Hotpoint sy36 oven
the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
does anyone know how to replace the heating element, also the fan on the top isnt working either
Jun 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Oven temperature
Replace the bake igniter in the bottom of the oven. It corrodes over time and as the resistance increases it finally reaches a point where the voltage is two low to open the gas valve. It's a ten minute job and the part cost $45-65.
Jan 22, 2008 | Amana ARGS7650SS Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
339 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
