Operating Systems
Problem for Operating Systems
Generic problem for all Operating Systems
VISTA home Premium: system protection tab...
By tom19511 on Mar 03, 2008
I can not create a restore point, because the system protection tab is missing under system properties. The only tabs available are Computer name,hardware,advanced,and remote.
However I can run system restore to rollback to a restore point.
Is there a way to fix the registry to make it (the system protection tab) show up?
I have not tried the restore function , yet. I really do not want to because except for this the computer runs great. thanks.
Comments:
Mar 04, 2008
- No, I do not...
Mar 04, 2008
- jitenok:
I can restore the system, I can not create a restore point, because the tab for system protection is gone.
Mar 04, 2008
- press other one option??
Mar 04, 2008
- the tab for system protection is gone. I would like to get it back...
Mar 04, 2008
- I know how to use the system restore. The tab for system protection is not there. I would like to get it back...As, I said I can use system restore, I just cant create a restore point.
Mar 06, 2008
- Still nothing... Any more suggestions??
Clarification Request
Posted by ser71 on Mar 03, 2008
do you have dual boot?
Sergio
Same Problem
May 14, 2009
-   jitenok, what are you talking about?   Yes, if System Restore is ON, you can do that, but the problem here is that it is not ON, and can't be turned ON if the System Rsetore tab doesn't appear in the System Protection Sub-menu of the System Properties.  Wiz? -   Guest
Mar 21, 2008
-   I have the same problem after installing SP1 to Vista Ultimate 64. Does this have anything to do with Kaspersky?-   dadto7
Best Solution
posted on Mar 26, 2008
Very Helpful)
dadto7
Rank: Apprentice
Rating: 99%, 7 votes
Tom, I had your same problem as I reported earlier and I feel now I can contribute to a solution instead of searching for answers. And boy, did I search.
I had some memory errors around this time but did not notice the "System Protection" tab missing until after I installed the SP1 update. I'm running Vista Ultimate 64 on a Polywell with an AMD 6000 chip (what a screamer).
Now to how I fixed my problem. Basically I had to go into the Group Policies which I never do and toggle a couple settings. Policy and/or Registry changes are only for the real brave so take caution. The web site I found that explains the process is:
here. I hope that link comes out but just in case it is "http://www.winhelponline.com/articles/216/1/Restore-point-creation-disabled-by-Group-Policy.html".
I'm not sure if it is needed or not but I toggled the "Turn off System Restore" also by changing to "Enabled" and then back to "Not Configured". After a reboot my "System Properties" show up and I hope it works for you.
As a side note I noticed that all things I looked at in the Group Policies was "Not configured". Maybe some Active Directory guru can comment on that.
Good luck, Nick
Was this helpful?
Yes
No
Solution #2
posted on Mar 04, 2008
Somewhat Helpful)
jitenok
Rank: Wiz
Rating: 79%, 140 votes
You can do this
  1. press start menu button
  2. click on program
  3. click on accessories
  4. click on system tools
  5. then click on system restore
  6. select restore my system.......
  7. And press next
Comments:
Mar 04, 2008
- You can creat restore point from there to press other one option
Mar 04, 2008
- thanks
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
ser71
Rank: Guru
Rating: 86%, 659 votes
http://support.microsoft.com/kb/322756
Was this helpful?
Yes
No
Popular Solutions for Operating Systems
Questions and Unsolved Problems for Operating Systems
Answer
How can I upgrade my royal 660 cashregisterlink to cashregisterlink pro
Answer
following image problam:C:\DOCUME~1\user\LOCALS~1\Temp\27f2_appcompat.txt
Answer
Keep getting errors,100,200,300 dated before the computer was made. SONY VAIO WIN7 64BIT
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Operating... Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
