Question about RCA R52WM24 52" HDTV Projection Television
Convergence menu not available on my RCA HDTV. Model R52WH74YX58
  • 3 more comments
  • landl Mar 03, 2008
    What is the part number for said fuse?
  • landl Mar 04, 2008
    I have not removed the back off of the set as of yet. Just doing a bit of advanced info gathering in case this is the culprit. Won't do me any good if I can't locate the little sucker...
    I was actually referring to locating the part for purchase. Need to locate a source here in town (Pittsburgh)...
  • texan1325 Oct 01, 2008
    Same problem. I have the bowed effect and triple image (one of each R G B) The fuse is not open. I resoldered the flyback and the problem still persists. Any further info would be great.
  • richmax1 Jan 08, 2009
    Same problem. Heard a low click, and convergence lost. As you said, no convergence available on the setup menu below autotuning. technician will be notified in Auburn, MA, as set is out of warranty. (purchased in 2006).
    Genius:
  • 1,030 Answers
So the set is completley without convergence? bowed and the 3d effect.]
There is a small brown rectangular fuse fl231> it is common for this to blow due to poor solder conections on what is known as the flyback. IF this is your problem then it not a difficult repair. i do them all the time at the shop in about 15 min. Getting the fuse is the most difficult thing.
Posted on Mar 03, 2008
  • Willie Howell Mar 03, 2008
    rca 259213 so i take it that you check this and found it open? remeber solder the flyback connections this is what cause the fuse to blow
  • Willie Howell Mar 04, 2008
    these fuses are located next too the flyback. this is the big black thing with the big read wire coming from it looks kinda like a cars distibutor. there are three small rectangular brown or tan looking fuses the fl231 is the middle one
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Convergence menu not available on my RCA HDTV. Model R52WH74YX58
The only fuse that will govern the convergence option is FL231 along with the two other components that you mentioned. If that didnt fix the issue the deflection board or the convergence power supply is defective. The deflection board is most suspect.
Posted on May 27, 2009
Slinteriors
  • 8617 Answers
Itsalmost that simple, But you will need to replace the FL231, DL231 and CP230 and that should take care of your problem. You can get the replacement parts at the following link under their RCA Parts category. The total cost is around 13.00 and shipping is free and they even send detailed instructions with pictures that show how to do the repair which is very easy.
http://servicemanuals.vstore.ca/
Posted on May 28, 2009
The picture looks 3D and when you select the menu all writing is in a U shape. The TV is a RCA HDTV and the model # R52WH74YX51. Serial #G402C10DZ, chassis #ITC222A, and was manufactured Oct. 2006.
Its more than likely the FL231 fuse has blown due to carcked solder joints on the flyback. very famous issue with that model if the auto convergence feature is no longer listed under the setup menu then you will need the convergence option missing repair kit from www.tvrepairworld.com
Aug 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV has bow on top and bottom of screen and convergence is misaligned or off with red, blue and green, which should created the laying of R, B, and G to create B/W or Color...and of course, there is no...
Thats a very easy repair that has a repair kit available called the ITC222 and ITC222A convergence option missing repair kits. Its available with instructions from www.tvrepairworld.com its listed under the RCA repair kits.
Jul 14, 2011 | RCA HD52W59 HDTV Projection Television
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
I have a RCA HD52w59 model an it needs conversion adjustment the picture has red,blue,anyellow around it tryed using menu button but no luck
the repair kit called the ITC222 and ITC222A convergence misssing repair kit should solve hat issue. The kit also contains instructions and is available from www.tvrepairworld.com
Apr 28, 2010 | RCA R52WM24 52" HDTV Projection Television
Cant find convergence on menu screen
The HD61LPW42 is a RCA DLP which doesnt have convergence. If the convergence is out of alignment you have a three CRT TV such as the D52W19, HD52W59 RCA Check the model number from the rear tag and let me know what the model number is.
Nov 21, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Where is the convergence on the rca menu screen
its under the settings option. If its missing you will need the RCA ITC222 convergence option missing repair kit available at the following link. The kit has the replacement parts and the CD with instructions on the repair.
http://www.tvrepairworld.com/
Jul 13, 2009 | RCA HD52W59 HDTV Projection Television
May 28, 2009 | RCA R52WM24 52" HDTV Projection Television
Convergence menu not available on my RCA HDTV. Model R52WH74YX58 I have installed all 3 new fuses as well as DL231 and CP230 and resoldered the pins on the flyback and IC, but I still have not got an...
May 26, 2009 | RCA R52WM24 52" HDTV Projection Television
Convergence problem on rca model d52w23
Replace convergence board or repair it. Try this with TV off Press and hold vol-and ch- at same time hold untill set comes on Now you should be in service menu Go to convergence Adjust the 16x9 mode.
Dec 21, 2008 | RCA D52W23 52" HDTV CRT TV
Showing picture in three segments
Test through MENU? explan that please. are there different colors that lead you to idea that is convergence.
Jan 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA R52WM24 52" HDTV Projection Television Logo
700 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
