Question about Cuisinart DLC-2011 PowerPrep Plus Food Processor
Cuisinart won't pulse
My cuisinart has power the top is on and lock. I press on and the light comes on. I press pulse and it won't do anything. There is a little black button on the front of the appliance. If I press that while pressing down on the pulse button it runs otherwise nothing.
  • Anonymous Jan 13, 2009
    When I go to lock it it will not run, what could be the problem> speck91854@aol.com
    thanks
I started from scratch with the assembly instructions. Got it together correctly and now everything works.
Posted on Mar 04, 2008
Cuisinart DLC-8S Food Processor: On/Off Switch not working
Replacement of the switch would be a likely repair unless other damage makes replacement impractical.
Apr 14, 2017 | Cuisinart DCC Food Processors
Cuisinart processor not working
I would check the switch that gets pushed in when the top is engaged. You might want to just push the switch in with a small screwdriver.... without the blade on the cuisinart of course. If the rotor spins it is a faulty switch.
Make sure you dont try this with the blade on.
I’m happy to help further over the phone at https://www.6ya.com/expert/bob_62dfa2f81bb55288
Oct 03, 2009 | Food Processors
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Power is available (light is one) but nothing
Sounds like a safety feature working. Unplug. Take apart as if you are going to clean it. Check all parts carefully to see if there is anything broken, like a nub.(Are all parts there?) Put back together, making sure they are fully engaged. Plug in and try. This happened to my food processor and it was a bit of dried food stuck in the bowls sliding track that kept it from clicking fully connected. Hope this helps!
Jul 19, 2009 | Cuisinart DLC-5 Food Processor
Put in nuts and turned to mush
It is extremely difficult to chop walnuts in a food processor, because they turn to powder within a few seconds. I have chopped them using both a Cuisinart food processor and a Moulinex La Machine. The difficulty arises because even after you have released the on or chop button, the blade continues to spin for a second or two. The Cuisinart DLC-8S is not particularly well-suited for chopping nuts, because the blade is not reversible - there are many Cuisinarts that do have reversible blades - a particularly good one is the Cuisinart DLC-2A, which has both a reversible blade and a Chop function (retails for about $29.99 to 39.99 nowadays).
The only way to have any success whatsoever with the DLC-8S is to press the pulse button and release immediately - only use a small amount of walntus - and then dump the bowl and add a few more at a time.
Apr 04, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
My mini cuisinart stopped working
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals (p.6 is most helpful):
http://www.cuisinart.com/share/man/10_man.pdf
Mar 23, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
None of the buttons work on my Power Prep Pulse 11-CUP
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
Mar 23, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart Prep 11 Plus Food Processor - Help!
Not sure if you found the solution by now but we recently had a similar issue. Make sure the bowl is put on such that the handle is facing the front of the processor. There is a little black button that gets depressed when the lid gets put on. We had to get the thing to work one night and spent hours trying to get the processor on and then trying to get a blender to work before finding the problem.
Hope this helps.
Sep 26, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Power red llight is on, but the motor/blades won't go
Well, now I feel totally foolish. The handle on the bowl must be toward the front of the bowl, not the rear otherwise the operating post won't engage.
Aug 22, 2006 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-2011 PowerPrep Plus Food Processor Logo
1,216 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
