Question about Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW8102SS model. We had a general power outtage. When the power came back on to the house, the microwave no longer was working. It will not accept any of the touchpad commands and the digital readout panel is completely blank. I'm just trying to locate a repair person for Emerson microwaves on Prince Edward Island, Canada. Postal Code: C0A 1K0
What probably happened when the power went out is that you
had a power surge or SPIKE as well, either before or after power was
lost and then restored.
This sometimes can happen just before the power trips at your
substation that feeds your house, or else it can happen when the power
comes back on.
There are safeguards that are suppose to be in place to prevent this from happening, but sometimes they fail as well.
If you are in a bad area that has frequent power outages I would
suggest adding an appliance surge suppressor to your microwave -
similar to those like they use on refrigerators.
If your microwave is a 110VAC unit and somehow 220VAC is crossed
circuit wise (as in underground, etc) then the same thing can cause
your present day problem as well. Happened to my neighbor once and the
same thing happened to their Litton Microwave. They gave it to me free,
as they were just going to throw it out anyway.
I was able to open it up and get the part # off the L.V. XMFR and
ordered a new one for like $10 direct from the XFMR mfr after getting
their factory phone #. Litton wanted $36 for their same identical part.
When this power outage happens like it did to you then you get a surge
of current that will overload the primary side of the LOW VOLTAGE
Transformer (XMFR) and causes it to go open circuit in the secondary -
as in - it makes a break inside the XFMR itself causing the Control
Panel to go dead as well. Because this AC XFMR is a step down type that
takes 110VAC and drops it down to say maybe 18-24VAC you can see why it
wouldn't like 220VAC on the primary side - as then the secondary side
would rise up to say 36-48VAC which is way too high for the DC
rectified voltages that run the Control Panel logic circuits, etc.
Nothing will work at this point except maybe for the cooking chamber
light - maybe? If the Low Voltage XFMR has a fuse in it's circuit that
fuse can be blown. If there is no fuse for that circuit then the L.V.
XFMR has to be replaced. Usually the XFMR part will cost anywhere from
$18 to maybe $35 if you can get one.
If you know someone that is handy with a DVM (digital volt meter)
perhaps they can OHM out the primary and secondary side of that L.V.
XFMR for you as I firmly believe that is your only problem.
One thing you might check first though is if there is a Circuit Breaker
(CB) on the back of the MW unit. If it has one chances are it may have
tripped, and by pushing the popped button back in - your problem would
be solved hopefully. IF it even has a CB.
Hope the info helps out?
Best regards,
Frank
Posted on Mar 07, 2008
Sep 06, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Aug 05, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Jun 07, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Feb 27, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Jun 06, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Feb 25, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Aug 15, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Jul 29, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Apr 07, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Jul 16, 2014 | Emerson MW8102SS 1100 Watts Microwave Oven
136 people viewed this question
i have emerson microwave model MW88888 how do I set the power
