Question about Sennheiser RS 130 Consumer Headphones
Not charging I bought the Sennheiser RS130 headphones about 1½ years ago now - and they've been working brilliantly. However, in the last couple of weeks, for no apparent reason, the "Charge" light stopped coming on. The headphones kept working, but after a couple of days they only lasted an hour or so. I've replaced the batteries (don't work at all), turned off the system and removed batteries for at least 30 seconds - but no luck. I'm thinking that I'm going to have to send them back, but as that's a jolly pain I thought I'd see if anybody had an easier solution. Thanks in advance
  • 2 more comments
  • Bruce1001 Mar 08, 2008
    The headphones still work just fine (with charged batteries), and the base still transmits excellently...but it won't charge as it's supposed to.
    Thanks for your help.
  • Anonymous Feb 22, 2009
    My new Sennheiser RS 130 red chargeing light is on however it never goes to flashing, trickle charge mode. The headset does not respond, no sound at all. No beeps, does not seem to be charged.
  • Anonymous Feb 23, 2009
    My RS130 just stopped working about 4 weeks ago. Tried changing the batteries with fully charged ones and still no response. The charge light is on and the green on/off light it on but not even a humm. I tried hooking it up to other audio sources but had zero response from the headset. Unless I can get them working I'll probably dump them because I'm one who believes it's sometimes better to cut your losses with electronics rather than try to repair them. Any ideas?
  • Anonymous May 18, 2009
    SAME SITUATION & PROBLEM WITH SENNHEISER 140. RED CHARGING LED NO LONGER LIGHTS. (THE GREEN & YELLOW LED'S ARE OK).
  • 3 Answers
Did you try charging the batteries with another charger?
Posted on Mar 08, 2008
Sennheiser HDR 130 with TR 130 transmitter not working.
If you twist the earpiece,one of them has two NIMH AAA batteries ,worth checking out if these are gone ,which is what happened to me.I was about to bin my rs130's and just stuck two new rechargeables and the earphones are working again!!!!!
As for $20 dollars from sennheiser for replacements!?!?!?
You should pick up two NIMH batteries for a couple of bucks on ebay or amazon.DO NOT USE ORDINARY BATTERIES!!!!!
Feb 09, 2012 | Sennheiser HDR 130 Consumer Headphones
I have not used the headphones for at least three days. Even though the headphones are on "off" they continue to keep charging and have been for a couple of days. What is the reason for the...
My Sennheiser HDR 140 headphones charge whenever you hang them on the charger. The charger will "trickle" charge them to keep the batteries fully charged. If you find when you use it the batteries discharge quickly it's time to replace them.
My batteries are about 2 years old and I still get about 8-10 hrs of use before needing to recharge
Jan 04, 2011 | Sennheiser Audio Players & Recorders
What batteries do i need for the sennheiser rs130 headphones please
You need 2 AAA batteries to put in sennheiser rs130
Thank You
Dec 02, 2010 | Sennheiser RS 130 Consumer Headphones
I have HDR65/RS65 Sennheiser wireless headphones. I disconnected them to move stuff around, then re-connected them. Now all I get is a 2 second cycle consisting of: 1 second of static that builds in...
Try connecting them to an MP3 player or connect wired headphones to the same source to make sure the sound source is working correctly. If that works, verify the voltage on the batteries is 2.4 volts after charging. Mine stopped charging fully and the headphones wouldn't work at all, but when I connected a couple of AAA batteries to it in series, it worked great.
Nov 15, 2010 | Sennheiser RS 65 Consumer Headphones
No sound from RS130 headphones
I'm having the same problem with the RS140. Only a few weeks old, and no sound at all coming out (not even the beeps). Have replaced batteries and tried a different audio source. Base station lights are on and indicating it is receiving an audio signal, but nothing is going go the headphones.
Jun 25, 2009 | Sennheiser RS130 Wireless Headset
How do you get a sennheiser RS 130 headset to work in a computer?
i told u so kayla. a sound card upgrade is necessary so the connection would work.
plz rate!
Mar 06, 2009 | Sennheiser RS130 Headset
Bad battery
A replacement battery can be purchased from Sennheiser for $20.00.
Battery Part Number: BA 151
Sennheiser Link:
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004146
Dec 24, 2008 | Sennheiser HDR-45 Consumer Headphones
Sennheiser RS130 does not appear to turn on
did you try to put regular batteries in to see if that works?
May 20, 2008 | Sennheiser RS130 Headset
RS 130 not working?
I am having the same problem...i tried resetting it as well...no luck
Jan 13, 2008 | Sennheiser RS130 Headset
Sennheiser RS 130 Consumer Headphones Logo
821 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
