Question about Indesit Washing Machines
Indestit widl126 flashing lights fault
Indestit widl126 shower 3 lights flashing 3 green lights these are easy iron/extra rince and 1200 600 spin all these flash green and power light flashes red this happened on program 11 special wash and it was while the washer was filling and rinsing anyone know the fault code and explanation of wots up, i found a coin in the filter and ive checked all the drain pipes, any ideas?
blaster99999@hotmail.com
Was faulty heater
Posted on Mar 04, 2008
WIDL126 flashing light No3 extra rinse). Machine starts to fill with water then the drum spins twice (a little too fast I think), then drains and just stops and the door lock light flashes fast along with...
If spin speed happening during what should be Wash speed then sounds like faulty speed control module/ could also be Tacho has fallen off end of motor;small round coil operated by a magnet which pulses a speed control circuit in the module/check also pump is okay and filter clean.Try resetting if you can,book will show you how to..Good luck
Apr 07, 2011 | Indesit Washing Machines
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
Indest wil103 has 3 flashing lights the power one and to green ones stain remover and extra rinse and want spin what is wrong please help
If the machin isnt able to evac the water, it wont spin. It will indicate error with 2 flashing lights + lock led. Check pump, drain hose.
Jul 26, 2009 | Indesit W 123 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
WIDl126 - door lock and easy iron flash
worth trying this! make sure the drain hose is only down the waste pipe about 6 inchs, and up off ground level about 24 inchs ie. 2 feet.If that don't not work it could be faulty pcb board!let me know.bye,close,ire.
Dec 23, 2007 | Indesit W 123 Front Load Washer
Indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Sep 25, 2007 | Indesit W 123 Front Load Washer
Indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
Jun 15, 2007 | Indesit WA 125 Front Load Washer
Washing Machines Logo
1,727 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
