Canon ir3300 code
My copier doest'n work and i got e000000-0000code every time ask me to cycle the main switch/
  • 106 Answers
You must call a service man,you have problem with fixing unit
Posted on Mar 03, 2008
Ir 3300 copier error code e000732-0001
Canon iR3300 Error Codes Code: E732-0001
Code
E732-0001
Description
A fault is detected by the main controller PCB in the communication between reader controller PCB and the main controller PCB
Causes
The connector has poor connection. The reader controller PCB is faulty.
Remedy
1. Connector, Reader controller PCB Is the connection between the connector J1014 on the main controller PCB and the connector J409 on the reader controller PCB normal? NO: Correct the connection. YES: Replace the reader controller PCB.
Below is the site this came from which lists all the error codes in case another occurs after you resolve this one
Canon iR3300 Error Codes List page 1 from 12
Aug 27, 2016 | Canon Ir 3300 Black & White Copier
Error code E000350-0001 in ir3300
Its the serial number board. Someone swapped the main controller out and didn't change the small serial number pcb with it. That board HAS to be returned to the machine or it will not function. Only way to get a new board is through Canon engineering.
Feb 11, 2015 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How do I fix error code E000014-000 for my Canon ir3300 copier
E014 is strain on the fuser motor. Is the lower roller cleaning roller clean? A build up of waste toner on it and could be sticky/tacky and causing friction. Take it out and clean it or replace it.
Sep 09, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How to rectify error code E000002-0000 of canon IR3300
The fuser may need to be replaced. Sometimes that code can be reset in service mode without replacing that part.
Service mode--- Additional functions button, then hold down the 2 & 8 key at the same time, then Additional functions button again gets into the mode. Then select Function, Clear(CLR),Error(ERR) then hit ok and cycle main power. If it resets-great. If not,you need a fuser.
Sep 02, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How to solve the code E00000000 in the Canon IR3300
The error code states that the machine doesn't sense the temperature of the fuser getting hotter. Usually this calls for the fixing film unit to be replaced because the thermistor has gone bad.
Jul 04, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Hard disc error
the error refers to PDL board mounting error- suggest if the machine has been moved or if any parts have been removed or replaced you check ALL pwb board connections this could take some time to complete try to start where you have been working in the machine first.
Jan 16, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Error code 0803 in ir3300 canon copier
The 24V output from the composite main power supply PCB is absent for 1 sec or more. Main cause The wiring is faulty (short circuit, open circuit). The composite power supply PCB or DC controller PCB is faulty.
Sep 06, 2011 | Canon Office Equipment & Supplies
Error code E000007-0000
I have machine of canon ir3300 this time show this problem in machine E0000007-0000.
Jan 12, 2010 | Canon imageRUNNER 3035 Black and White...
Each time l switch on my machine canon ir3300 l have e000007-0000
Try this press additional functions,2 and 8 keys at the same time,additional functions,copier, function,clear,err.power off and on. If that does not work you will need a tech to fix your fixing unit.
Oct 01, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
