Question about Sansui HDLCD3200 TV
PC Hookup When I hook up the PC I don't get a picture and it says no signal
  • dutch193 Dec 22, 2008
    televison hooked up to cable sound gos out slowley starts ok gos to nothing in about 10 min
  • 61 Answers
You have it on the wrong input selector. switch it to the right one at the monitor
Posted on Mar 03, 2008
Game console hook up
What type of hookups are on the back of tv ? Do you have an HDMI hookup if so try using that If your tv comes with a game mode look in back before u hook it up to place it in right spot. One last thing why don't you try hooking up old fashion way buy adapter for regular cable hookup and use channel 3 or4 that might help
Jul 30, 2012 | Mitsubishi CS-32307 32" TV
Keep getting no signal on 32 in lg
Start at the beginning:
Hook a DVD to one of the rear sets of audio/video jacks--go to that input and verify it works.
If so, hook the direct TV to another rear input and select that---if no picture that way---the box may be the issue or wrong hookup--composite to composite or component to component (most likely).
If the set works with DVD and not DIRECT TV it is not smart enough to know what is hooked to it.
In that case a setting or the connection out from the box is the problem---check on screen menu for the box in setup.
Box may need to be rebooted with it connected to set or wrong hookup of cables.
Mar 31, 2012 | Televison & Video
When i turn on the tv its norman picture but about 5minutes the picture will snowy what is the problem of that? tnx hope u help me
A snowy picture after warmup is either in the set or not.
What you may want to do to begin with is hook up a DVD player or something else to ONE OF THE VIDEO INPUTS ON BACK OF SET this will narrow it down to the tuner or the front end of the set.
If A/V hookup works you always have the option to hook the output of the cable or sat box to those same kind of rear connections- bypass the tuner and front end signal circuits completely.
As it only happens when on a short time not likely to be a hookup or bad connection there but check them anyway.
If using a box of some kind run the cable or sat direct without it--bypass the box to rule it out.
Last is if tuner in set is bad it would have to be removed and or rebuilt/replaced---not cheap parts and labor
Mar 20, 2012 | Televison & Video
I want to put a new 4-wire/prong dryer cord, and I don't know how to conect
Hi sacra4487...
Go to this webpage and see a picture of how to hook up your dryer cord
Free Answer...Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Jun 12, 2011 | Crosley CDE6000 Electric Dryer
Cannot get a signal from presenter to tv
Have you selected the EV 308 button on the video selector switch panel. If you have and still no picture, the camera or the switch assembly could be faulty. Try hooking up a VCR or a DVD player or video camera to one of the "Video in" teminals and select AV1 or AV2 . If you get a picture through to your TV your camera on the presenter is faulty.
Nov 26, 2009 | Office Equipment & Supplies
I have my polaroid hooked up with an hdmi cable
Thats because your TV is not high definition and cannot process the high def signal. serial hook up does not give a highh def signal.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Nov 09, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
How to hook up speakders?
The monitor does not have output sound since it is only an input device. You will have to hookup the speakers to your device (laptop, computer, gaming console) that you are connecting to the monitor. The speakers in the monitor are ready to receive a signal so that it can amplify it and let you hear it. If you hookup your speakers to the monitor it is the same as if you were trying to hookup two sets of speakers to each other.
If you need further help, reach me via phone at https://www.6ya.com/expert/hugo_f827544e52871d36
Nov 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Projection set- 57h82 - need plug location for signal board hookup from control panel on front,and av jack panel,and hookup for if module standing up
FRONT PANEL HOOK UP IS EITHER TO IR PICKUP BOARD ON THE TOP OF THE BLOCK BY THE CRT LENSES OR ON THE FRONT OF THE SIGNAL BOARD.
Jan 22, 2009 | Toshiba 57H81 57" Rear Projection...
HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
Apr 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
HOoking up DVD/VCR without correct connectors
either use an old vcr to act as a signal converter or go buy an "rf converter" from an electronics store to change composite audio/video signal to channels 3 or 4 and that should do the trick.
Dec 26, 2007 | Sansui COM311AD 13 in. Combo
Sansui HDLCD3200 TV Logo
199 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
