Question about Acer 90.00012.30B Computer Speakers
Add speakers I want to add a set of speakers to my computer to use in a different room a have bougth the speaker cable but how do I know the conector that I have to use to plug it in
  • 38 Answers
1.check the femails connectors and then buy mail connectors with extension according to requirement
Posted on Mar 04, 2008
Cables
mcdevito75 here, Best Bet, speak with Radio Shack about this.
Jun 19, 2010 | Altec Lansing AVS 300 Computer Speakers
Battery part no Mh29654 for iM600 speaker need to purchase a new battery. Proving to be a night mare to obtain as this has 3 wires with sq connecter.Model no McR18650 3.7v
buy a cilyndrical 3.7v battery,a bougth a onu with 3000mah. and use the conectors from your old one,they are built-in circuit take it apart and reuse it
Mar 02, 2010 | Altec Lansing Inmotion-IM600...
I have some logitech Z4 computer speakers
If your TV has a headphone socket, then plug the speakers into there, then (you have to do this for some TVs, but not others), go into the set-up menu and turn the headphone volume to 70%. Switch on the Z4 and sound should come out, assuming all connections are correct.
Jan 03, 2010 | Logitech Z-4 Computer Speakers
Radio station broadcast through speakers
First off no offence but this is happening because they are cheap .. (i know from experience lol)
okay this sounds dumb but it works radio waves cannot go through brass so setting something brass by your speakers will solve this problem
Please Rate Me
May 28, 2009 | Logitech X-240 Computer Speakers
I Do Not Know How To Connect Boston Micromedia To My Computer
The Boston Micromedia speaker set comes with two speakers (right and left),a subwoofer, and a complete set of cables to connect everything up.
1.) Position the speakers. The two small speakers typically are spaced equal distance apart on a desk/table top to the benefit of the listener. The sub-woofer typically rests under the surface, on the floor for example.
.) Connect the cable sets to the back of the two small speakers along with the speaker feet.
Note: the small speaker with the volume control knob will have three cables coming from it. This will be the "right" speaker. The other speaker will have a single cable and will be the "left" speaker.
2.) The cable ends will be color coded to match the jackson the sub-woofer. Match up the color coded cables to the respective colors on the subwoofer as follows:
(a) White cable end (left speaker) to white jack on sub-woofer.
(b) Red cable end (right speaker) to red jack
(c) Purple cable end (input) to the purple jack
(d) Green cable end (computer out) to the computer's microphone output jack.
Note: if any of the cables are too short to reach their jacks for whatever reason, an extender cable with a female and male end can be purchased relatively inexpensively to make up the difference in distance.
3.) Power up the system (plug in power cables to the sub-woofer and wall), play some music, and adjust the sub-woofer sound (control knob) to suit listening pleasure.
A nice little set of speakers, I had mine for some years now and continue to enjoy them. Good luck!
May 17, 2009 | Boston Acoustics MicroMedia Computer...
Add 2 speakers outside on a 6 speaker surround sound and hear all
You won`t get surround sound mix with 2 speakers, you can have a 2nd zone but this will only play a "Stereo Sound" if you have that playback option with the SC-RT50, what you will need is a speaker selector switch or better known as an A & B switch, this will ideally run from the front left and right speaker output of the receiver into the A & B switch then run into each pair of speakers inside or outside, what is common nowdays are receiver that are known as 2nd zone connections where you can have 2 sets of speaker in different rooms, unfortunatly the SC-PT50 does not have this option.
Feb 03, 2009 | Panasonic SC-RT50 System
Converting 2 channel amplifier to 2.1 amplifier
it is not availlable to do such convertion.
Jul 05, 2008 | Audio Players & Recorders
Operating with/without the control panel
You could try hooking them up to another speaker that has the input connections. I have done this before with several different speakers and daisy chained the connections with several speaker connections and they worked great. I had surround sound all over the room. You might run into a problem with the main speaker that you plug into not being able to push all of the speakers that you have but you might get lucky. Those speakers say that that carry 550 watts.
I recently bought a set of speakers that stated that they push 100 watts. The sub was putting out 50 watts and the others were only putting out 25 each. I hooked up a 100 watt speaker to it and it worked. You might be able to contact logitech to get the other speaker that you need. That set of speakers looks awesome on the site. This is the specs for the other speakers
I think that this is what you wanted to know. If it was not your solution, let me know. I will help you more. I might not be understanding your question correct. I have referred your question to someone on the site that works with logitech.
Jun 09, 2008 | Logitech Z-5500 5.1 Digital Speaker System...
JBL encounter
HI! Red14 happy holidays
Well, may be a lot things, from bad cable, welding inside , or bad resistor is burn. but check the cable, and if you can open the panel on inside speakers, try to figure out if the cable is not loose, or bad.
Nov 27, 2007 | JBL Encounter 2.1 Computer Speakers
Working on tv/playstation 2
You can easily buy RCA conectors and splice them. Remove the 1/8 plug from the speakers and strip the ends and add the RCA connector. I am not so sure of what it would sound like but the ohms may be different.
Nov 06, 2007 | JBL CREATURE II Computer Speakers
66 people viewed this question
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
