Question about Toshiba DKT3014SDL Corded Phone
Change the voice mail message
Need to change message to system when phone isn't answered. HELP!!
  • Anonymous Sep 23, 2008
    I have the same phone and need to set up the voicemail. Cannot locate the documentation on how to do this, can anybody assist. Than you.
What voicemail do you have?
Posted on Mar 05, 2008
How to leave a voicemial message
There are three elements to voice mail; having a Panasonic brand voice mail system, recording the greetings, and setting call forward conditions. Which ones have you done?
The default access to voice mail is extension 500 on the intercom, but we used to use 165. When you dial it, the lady says "welcome to the Panasonic voice processing system". If she doesn't or you're asked for a password, or you have not done the tutorial, then you need to do that and it guides you to the setup of the greetings, name, and password change. After that, you dial *710x 500 (or your VM access) # on the inercom to set call forward to voice mail, with 4 being no answer (my preference since it gives me the option of answering the 2nd call or letting it fall to voice mail), or 5 for Busy/No Answer.
The message manager (mailbox 998) and the system owner (mailbox 999) has the ability to access and change how the voice mail system performs. The owner can change your name for the directory or reset your password and/or
setup or delete your mailbox.
Carl
Aug 09, 2012 | Panasonic KX-T7630 Corded Phone
Answering machine message
The KX-T7730 isn't an answering machine. You need to refer to the documentation for whatever answering/voicemail system you have it connected to. Alternatively, repost your question specifying the make and model of the answering/voicemail system.
Jul 30, 2012 | Panasonic KX-T7730 Corded Phone
How do change the outgoing "Night Mode" message in the Voice Mail System on NEC Electra Elite DTU 32D-1?
If you are using an Active Voice product (typical w/ NEC) you need to change the hours of operation on the voice mail system. "Night Mode" only changes the ringing characteristics of the phone system and where calls ring, not the greetings that play on the voice mail. The voice mail plays a particular greeting (Day/Night/Holiday) based on the time of day specified in the schedule. The system administrator for the voice mail would have to make this change.
Jan 24, 2012 | NEC Electra Elite 32D-1 Corded Phone
Even though my answering machine indicates it is on, noone can leave a message.The response is that the mailbox has not been set up.Can you help? Thank you.I have had this system for quite a while and have...
A "mailbox not set up" message is coming from your telephone line voice mail system, and not from your telephone answeringmachine. What this means is that the voice mail on the phone line is picking up before the answering machine has a chance, and since the mailbox hasn't been set up it can't take any messages. So there are two things you'll need to do.
First, you'll need to set up your voice mail. You may need to contact your telephone service provider for setup instructions since not all systems are the same, but here's how it usually works. From your home phone, call your own number so you reach your voice mail. You should get the message that your mailbox hasn't been set up, and will be prompted for an access code to get to the setup menu. The access code is usually the last four digits of your phone number, and you'll be prompted to change it to something else as part of the setup. Through the setup main menu you can record your greeting and set up other options like the ring count before the voice mail answers. Set it for a number larger than the setting on your telephone answering machine. (I have my answering machine set to 4 rings, and voicemail set to 6.)
Step two is to verify the ring setting on your answering machine. Four rings is a common default setting, but it's adjustable on the phone. Most newer phones have menus that you access from the handset to set change settings, while older models have a switch on the base unit.
Once the mailbox is set up and you have your answering machine set to pick up first, everything will work as you want.
Aug 14, 2011 | Uniden DECT 6.0 Cordless Phone
VOICE MAIL INACCESSABLE - PHONE JUST RINGS
Voice mail was down. Called a service tech.
May 29, 2009 | NEC DTU 8D-2 Corded Phone
Change night message
the night mode message that is being used is the main phone's (phone with lowest Ext. number) night mode message that was customized through it's voice mail.go on the main phone and listen to its voice mail. (voice mail ext. usually 165)continue listening until you hear some options.select the voicemail management optionthen select the change personal greeting optionthen select the after hours greeting optionhope this helps!
Feb 19, 2009 | Toshiba DKT-2010 Corded Phone
Voice mesage
What manual did you download, where is the message located, and what is it recorded on?
A 7433 phone is just a phone, it has no messages. It is connected to a TD-816/1232 Key Service Unit and a TVS/TVM/TVA voice mail system if it's Panasonic branded.
When you call in to the TD system, the voice mail answers the call and plays the Auto Attendant greeting. Is this the one you want to change? Or do you want to change the greeting that you get after the AA answers any they dial your extension?
Each of those messages can be changed from the Message manager's box or from your own mailbox, using the codes and passwords supplied at installation.
Carl
Aug 27, 2008 | Panasonic KX-T7730 Corded Phone
Changing message on Comdial Impact Telephone
Sounds like you are trying to change a voice mail recording. Your Comdial phone can be used on several different Comdial phone systems and with several different voice mail systems that all program and set up differently. Do you have any manuals or instructions for your voice mail system? If not, you will need to find out which voice mail you have and try to locate manuals.
To change main greetings, etc.. you would need administrative rights to the voice mail. There will probably be a password, hopefully you know it or it's still at default.
Nov 28, 2007 | Comdial 8324S-PT Corded Phone
Changing message
I am a new voluntary worker to the charity. The operating manual is lost. I like to change the date and time on display. Can you help!
Nov 20, 2007 | Lucent PARTNER18 Corded Phone
Recording messages
You are asking about changing you voice mail and phone system settings. Your phone can work on several different Panasonic phone systems and you could have different voice mail systems as well.
The phone KX-T7633 has only a user guide that covers the basic features of the phone itself. You need a programming and installation manual for your phone system AND your voice mail. They are not the same part and have different manuals.
So, your first step is to find out the model number of your phone system and voice mail system.
Oct 09, 2007 | Panasonic KX-T7633 Corded Phone
Toshiba DKT3014SDL Corded Phone Logo
85 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
